Username Post: Wiper motor running ?backwards?!        (Topic#357213)
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
07-13-19 05:01 PM - Post#2770629
So I hooked up and tried my 2 speed wiper for the first time yesterday. The results were completely unexpected. Full disclosure: I had this wiper motor completely apart for a rebuild.
If I have the wiper arms on in the recommended positions at park, the motor wants to sweep into the engine compartment!
To troubleshoot, I taped a pencil to the post on the driver side with the pencil in the 12 o'clock position as you look at it from the driver's seat. When I turn the switch on, it cycles first to approximately 11 o'clock then sweeps to about 4 o'clock before returning to about 12. So the swept arc is about 12-4. From the drivers seat, it should start at 3 and sweep UP to 11.
Can a wiper motor run in reverse without messing up some of the camming and gearing? Or is it possible to attach the output arm of the wiper motor to the mechanism under the cowl that will cause reverse rotation?
We're having some fun now. Hopefully someone has some answers.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
07-13-19 07:54 PM - Post#2770636
    In response to Gaspains
I had some funky things happen when I installed my single speed motor into a 2 speed wiper car. Shut off they wipers were stopped in wrong place. Sweep was wrong too. The problem turned out to be the arm on the motor. Single speed arm is different than 2 speed one. I changed the arm and they worked properly then.
Texasray
Texasray
Reg: 11-01-16
07-14-19 08:09 AM - Post#2770665
    In response to bigbowtielover
That would be my first thought, the arm is wrong or clocked 180 deg. out of position.
6T5
"2nd Year Gold Supporting Member
6T5
Loc: Asheville, NC
Reg: 07-22-17
07-14-19 09:28 AM - Post#2770669
    In response to Texasray
Try unhooking the arms and let the motor cycle a few times and turn off. It should be in the correct parking position then reattach the arms and try it. If this doesn't correct it, then the motor is probably clocked wrong from the factory and needs to be replaced.
...Ed
1965 Impala SS
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
07-14-19 09:56 AM - Post#2770671
    In response to 6T5
Ed
It's the original wiper motor that was on the car when I got it in 75. It worked then. I'm the only variable in that equation.
I like the idea of cycling and seeing if it will park in a different position.
Kevin
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
08-08-19 08:59 PM - Post#2772766
Bingo! I had the drive arm off by 180!
So if the wipers want to wipe down instead of up, you've got the drive arm wrong on the wiper motor.
Kevin
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
Execution time: 0.183 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:21 AM
