Username Post: Turn signal adjustment and cancelling cam        (Topic#357211)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
07-13-19 02:36 PM - Post#2770620
So my turn signal works for left and right. When I go to turn it off on the right it still stays on. also the cancelling cam isn't working and makes a bunch of clicking sounds like it's trying to cancel when I make a U turn.
Can I adjust it without taking the whole steering wheel apart?
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
07-15-19 01:15 PM - Post#2770756
    In response to Eth727
In order to get to the mechanism to do anything the steering wheel will have to come off so the horn stuff will have to be removed as well
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
08-05-19 06:55 PM - Post#2772490
    In response to PLS
Nothing short of a pain these things. It seems the turn signal system in general on these cars is not incredibly reliable from what I am seeing.
Me
Execution time: 0.068 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:19 AM
