Username Post: What are these parts called        (Topic#357199)
drhach
Reg: 05-30-19
07-12-19 12:22 PM - Post#2770542
Hi everyone, new guy here with a really dumb question. On 61-64 2 door post cars, what is the metal surround that goes around the rear quarter window called, and how are they attached?
Sweed62
Sweed62
Loc: NotUS.Language warning#1
Reg: 10-24-04
07-12-19 02:02 PM - Post#2770552
    In response to drhach
Very velcome drhach
All questions adds something to this forum.
I suggest: drip rail chrome trim, and they are cramped over the drip rail.
Its actally stainless steel and takes a lot of carefullness to dont ruin while removing.
I have done it but i hope someone more experianced here could give you more specific advice how to remove it if that is what you are going to do.
You are very velcome.
Svenne
Edited by Sweed62 on 07-12-19 02:05 PM. Reason for edit: No reason given.
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
07-12-19 03:37 PM - Post#2770558
I'm going a different way with this question. I think the question is regarding the quarter window frame.
1) The lower horizontal part is part of the quarter panel assy
2) The front vertical piece is the outer lock pillar
3) The upper part of the window frame is made up of two separate pieces. The outer roof rail has the forward portion of the upper frame.
4)The back half is the panel between the quarter glass and back glass (sail panel) and is called a outer roof extension.
If the window frame is damaged, the easy way is getting a used quarter panel. This will give you all the parts. The individual pieces are not available new.
Tom
1963 Chevrolet ?
$121.00
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
07-12-19 04:07 PM - Post#2770560
Thumbs up for a post car I have a 4 door
- Dave
1964 Impala 4-door sedan
drhach
Reg: 05-30-19
07-13-19 12:48 PM - Post#2770617
    In response to Swifster
Thanks Swifster. I was hoping somewhere there was a name for the combined pieces. I assume they are all welded in place.
Regards,
Dan
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
07-13-19 07:49 PM - Post#2770645
I would think so...
Tom
1963 Chevrolet ?
$121.00
Execution time: 0.173 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:34 PM
