Username Post: 1951 radiator cap        (Topic#357198)
Jeff1951
Loc: Bloomfield Township, MI
Reg: 11-12-18
07-12-19 11:47 AM - Post#2770535
Can anyone provide a photo of an original cap from a 51 Styline Deluxe with 216 CI manual transmission? The one I have is marked "TVS" on one ear and "RC-2 4 lb" on the other. The parts book shows 2 part numbers, one being an RC-2 4 lb stamped "501" and a second that I have not seen.
Jeff
2blu52
2blu52
Reg: 03-12-02
07-12-19 04:21 PM - Post#2770555
    In response to Jeff1951
The one you have is a pressure cap, the car did not have a pressure system and the cap was pretty plain jane.
THOMAS JEFFERSON
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
07-12-19 07:55 PM - Post#2770567
    In response to 2blu52
Not the best photo, but of a 1950 216. 1951 216 would have had the same type of cap. No levers, not even any printing or graphics on it; almost completely flat with squared up shoulders on it. Zero Pressure systems in he both he 1950 and 1951 Chevrolets equipped with the 216. The 4 LBS. cap was intended for the 235 PowerGlide engines.
Attachment: PICT0378.jpg (828.02 KB) 12 View(s)
1951 Fleetline
Jeff1951
Reg: 11-12-18
07-13-19 07:03 AM - Post#2770587
    In response to RAM_51
Thank you both for your responses! The cap on my car was obviously replaced be a previous owner with a new service replacement or reproduction. The P&A catalog shows a different part number for Power Glide than for manual. The PG one is available on eBay and from every vendor. This one is pressurized as is the one I have. The question is, is there a negative effect using the 4 lb. cap verses the unpressurized one? The car stays nice and cool now but would it also stay that way with the un-pressurized one?
Thanks again for your help.
Jeff
2blu52
2blu52
Reg: 03-12-02
07-13-19 07:37 AM - Post#2770588
Radiator construction is the key here. The pressurized system radiator had a small shelf built into the end of the fill pipe, the cap would tighten down on that sealing the system. When pressure hit 4 pounds then the relief valve would open. If you do not have this radiator then the pressure cap will not work and actually just becomes a standard cap, The radiator you have will probably handle 4 pounds with no problem.
THOMAS JEFFERSON
RAM_51
RAM_51
Reg: 12-28-02
07-17-19 06:37 PM - Post#2770946
This is an AC brand:
LINK:
https://www.ebay.com/itm/NOS-37-39-BUICK-3 7-38-CAD...
1951 Fleetline
Jeff1951
Reg: 11-12-18
07-18-19 07:51 AM - Post#2770974
Ram_51- Thanks for the photo! This is very helpful. I will look for either an NOS GM part (#594498) or thos RC10 (#850901 which may be a later number for same part).
Jeff
Jeff1951
Reg: 11-12-18
07-20-19 02:23 PM - Post#2771161
Update- I found a used one at a swap meet today and soda blasted it and used muriatic acid to remove any plating. I replated the zinc (Caswell kit) and it looks perfect on the car. Oh, and it cost me $1.00! Thanks for all your help.
Jeff
Execution time: 0.096 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:25 PM
