 Page 2 of 2 <12
Username Post: Need shifter for 4 sp 1965 Chevy Impala with a console        (Topic#357180)
Estimated Prophet
Loc: Oakland, CA
Reg: 07-28-18
08-22-19 09:55 PM - Post#2773850
    In response to 427SS65
Gents, picked up this kit after missing out last month (same guy, same item numbers).
FULL KIT
So, how complex of an install is this? I want to move away from the guy who's done work on the car so far. Should I be looking for a particular skill set or is this pretty straight forward? Any classic car shop? I could take the car to San Jose (hour drive) to a guy my brother uses on his 69 Camaro. Might be overkill though.
Thanks for the advice gang!
Jonathan
1965 Chevy Impala 396/325 Convertible Ermine White with Red Interior, 4 Speed with Air Conditioning
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
08-23-19 04:37 AM - Post#2773862
    In response to Estimated Prophet
If you have a Muncie transmission and your shift levers attach with a stud and nut you should be good to go. If the levers attach with a bolt you will have to get levers for that arrangement, the slot size is larger. (if my memory is correct)
eodcoduto
Loc: Washington D.C.
Reg: 09-22-18
09-08-19 06:45 AM - Post#2775039
I found this locally.
https://baltimore.craigslist.org/pts/d/dundalk-che...
 Page 2 of 2 <12
Execution time: 0.128 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:47 PM
