Username Post: coolant shutoff OR bypass        (Topic#357164)
aero_nautical
Loc: Arkansas
Reg: 09-12-10
07-09-19 01:37 PM - Post#2770306
1993 Suburban K1500
I want to get a little better Air Conditioning performance out of my rig and I have heard of people putting a shutoff valve on the heater hose that comes off the intake manifold to then connects to the inlet of the heater core.
My question is: Will it starve some other place coolant that needs it?
I was wondering if I should devise some method of bypassing the heater core that I can switch on and off or just install a shutoff.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
07-09-19 07:53 PM - Post#2770342
    In response to aero_nautical
Just install the ball valve and shut it down. I have had a manual valve on almost every one of my domestic vehicles over the last 15 years. TBI G20 van, my Vortec Express van, my 4.7 Dakota, and my 5.7 Ram... My import stuff Nissan and Infiniti came factory with an electrically operated valve.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-09-19 09:38 PM - Post#2770347
As 1983G20Van said, it won't hurt a thing to shut it off. I bought an Edelbrock Permormer RPM. The hole wasn't even in the intake. I had to drill and tap it so I could have a heater.
If Edelbrock blocks that port, it must not be necessary. I put a ball valve in the hose and it lowers my vent temps about 4° when it's shut off. It doesn't change the coolant temp a bit with it open or closed.
Jeff
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-10-19 06:47 PM - Post#2770419
    In response to bowtie44s
My toyota has a valve, the ac blows so cold, and the heat works great. They should all have a valve.
Should not hurt anything
Old School GM fan FOREVER
tcndeb
Reg: 04-18-04
07-11-19 06:28 PM - Post#2770499
I have a ball valve on my 92 Blazer. I can get about 5 degrees cooler with the valve closed. The only downside is that your A/C will run on max cold. If it gets too cold, which mine does in the mornings, turning the temp control up does nothing because you have no warm air to mix in.
'92 Full Size Blazer
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-11-19 06:39 PM - Post#2770501
    In response to tcndeb
Can probably run a cable through into the cab to control it.
aero_nautical
Loc: Arkansas
Reg: 09-12-10
07-14-19 06:11 AM - Post#2770659
    In response to rockfangd
Excellent, excellent news fellas! Thanks so much. Love you guys on this forum!
rain_man_rich
Loc: Grants Pass, OR
Reg: 02-09-14
07-14-19 12:43 PM - Post#2770689
If you wanted to get real cute you could go with something like this and connect it to the power for the A/C switch. I don't see it being a big power draw so it wouldn't need it's own relay or anything. It does have a max operating temperature of 180 degrees so it would be working right at or slightly above it's temp limit.
https://www.adafruit.com/product/996?gclid=Cj0 KCQj...
Edited by rain_man_rich on 07-14-19 08:39 PM. Reason for edit: No reason given.
07-16-19 06:57 AM - Post#2770833
    In response to rain_man_rich
Look at a FOUR SEASONS 74781 valve. It's vacuum operated. When the engine/vac is off, water can flow through the heater core. Heat will dissipate faster. On my truck, I plan to tie it off (bypass the heater core) until winter.
For winter, an variable flow option is good: HVAC Heater Control Valve-Shut-off Valve 4 Seasons 84706
Edited by gchemist on 07-16-19 07:05 AM. Reason for edit: No reason given.
Execution time: 0.173 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:10 AM
