Username Post: Steering wheel moving in and out        (Topic#357154)
LSS1333
Reg: 05-13-15
07-08-19 08:20 PM - Post#2770228
Hello everyone,
Work is relocating me and my wife and they are going to transport my 63 impala SS convertible ... if it starts, stops and steers.
I have been working really hard to get everything done (installed engine and transmission, new rear end, and just did brakes, brakelines, fuel tank and new fuel lines and felt ready to finally drive around the block to make sure everything is working.
When I eased onto the gas pedal, I noticed that the steering wheel moved about an inch or so towards me. I immediately backed up (the 20 feet from my garage) and parked the car.
What would cause the steering wheel to move "in and out" on my car? I need to fix this ASAP as they will be here on Friday to load it onto the trailer for transport.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
07-08-19 10:41 PM - Post#2770232
    In response to LSS1333
There is a spring around the steering shaft - at the bottom of the black painted steering tube under the hood.
There is a clamp just below that spring. Loosen that clamp - it’s a 7/16 inch bolt through the clamp and push it up against the steering column seal and retighten the clamp so the spring pushes against the seal that is in a metal housing bolted to the bottom of the shaft
-that will tighten the column so you can’t pull it toward you.
This all assumes that the column was assembled correctly with the parts I noted above.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
LSS1333
Reg: 05-13-15
07-09-19 08:28 AM - Post#2770269
    In response to pvs409
Thank you!!!
I will try that as soon as I get home (in about an hour). Will let you know if it works.
Thanks again
junky
Loc: Northeast CT
Reg: 06-27-10
07-09-19 08:52 AM - Post#2770274
Make sure that you have insurance on the car before they take it. Check with your insurance carrier to make sure that it is covered when in their possession. When I had a car transported from the West Coast to the East coast, the car was damaged, and they claimed that the damage was there when it was picked up. Being that I wasn't there to photograph the car in advance, I had no way to dispute their claim of damage. All too often, to you, it is a prized possession, to them, it is just another old car.
LSS1333
Reg: 05-13-15
07-09-19 10:54 AM - Post#2770288
It worked just like you said. Thanks again!
LSS1333
Reg: 05-13-15
07-09-19 10:56 AM - Post#2770289
    In response to junky
Excellent point. I will be sure and take photos before they arrive this weekend.
It is a full on project, so there isn't much they can do to hurt it, but it will be great documentation in case anything happens in transit.
Thanks for the tip!
Swifster
Loc: Sterling Heights, MI
Reg: 05-26-18
07-09-19 11:58 AM - Post#2770292
Companies like Hagerty and Grundy will insure a project.
Tom
1963 Chevrolet ?
$121.00
LSS1333
Reg: 05-13-15
07-09-19 12:54 PM - Post#2770294
    In response to Swifster
I have it with Hagerty's.
junky
Loc: Northeast CT
Reg: 06-27-10
07-09-19 07:40 PM - Post#2770336
Ask them if it is covered for theft and damage while it is in the hands of the transporter. Better to ask beforehand, than afterwards.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
07-10-19 06:27 AM - Post#2770369
Every transport company I've used they took pictures and noted on their sheet any damage prior to taking the car.
Swifster
Reg: 05-26-18
07-10-19 07:07 AM - Post#2770374
It does cover transport. I would do as suggested and get pictures prior to pick up.
Tom
1963 Chevrolet ?
$121.00
Execution time: 0.1 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:46 AM
