Username Post: Oil change        (Topic#357140)
Chad1950
Reg: 05-06-19
07-07-19 01:11 PM - Post#2770122
I’ve got a 1950 235 i changed the oil today .. it has the old canister and filter .. The canister just has one line coming out of the bottom I’m not real sure that’s Right it did have oil in it when I took the filter out !! All the pictures I found It showed two lines one coming out of the side and one coming out of the bottom.. can anyone give me information on how that can work with just one line?
Chad1950
Reg: 05-06-19
07-07-19 01:16 PM - Post#2770124
    In response to Chad1950
I should’ve been more clear It’s a 1950 Chevrolet with a 235 engine .. sorry
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
07-07-19 02:02 PM - Post#2770128
It doesn't if stock accessory. it needs an inlet and outlet. They are small lines as filter only filters 10% of oil flow. I assume it's mounted on the intake.one outlet on upper side and one outlet in bottom.
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
Chad1950
Reg: 05-06-19
07-07-19 02:12 PM - Post#2770130
    In response to one4dad
Yes...one in The bottom and one in the side .. The side one is plugged off ! The bottom one runs to the block
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
07-07-19 02:19 PM - Post#2770131
Oh boy, well you need a new line, you can order one from "The filling Station" or other supplier or go to a good parts house, purchase a grease gun hose and add a swivel to that and there you go. Remember wtih a running filter you need to add one quart for the filter or a total of 6 quarts per oil/filter change.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
Chad1950
Reg: 05-06-19
07-07-19 03:07 PM - Post#2770139
    In response to 2blu52
My dad and I Was looking at it when we changed the oil something wasn’t right with the canister I see where the line goes in the tee ... not sure why someone took it off ! But I’m going to order one !! Thank you guys!!! For the info
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
07-07-19 08:42 PM - Post#2770158
Chad, do you have a manual yet?
http://chevy.oldcarmanualproject.com
http://chevy.oldcarmanualproject.com/shop/1949_53/...
Dean50
Chad1950
Reg: 05-06-19
07-08-19 03:32 AM - Post#2770167
    In response to Dean50
Hey thank you !!!! Man you guys are awesome!
53sd
Reg: 12-08-08
07-08-19 03:40 PM - Post#2770214
Yah eh! I second the grease gun hose idea.Looks great.
Or a line from the weathered rack at NAPA.
[way cheeper, looks stock, done today]
Execution time: 0.194 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:18 PM
