Username Post: Gear Vendors Overdrive        (Topic#357127)
Marked4life
Reg: 07-06-19
07-06-19 06:52 AM - Post#2770034
I have a 1963 Impala SS with a M22 4 speed that I want to add a gear vendors overdrive. Has anyone any experience with this application or similar
installation?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
07-06-19 08:27 AM - Post#2770042
    In response to Marked4life
I don't think it will fit the x frame right behind the transmission -not enough room.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
gofastwclass
Loc: In the garage
Reg: 08-19-14
07-07-19 08:00 AM - Post#2770101
I met a guy with a gear vendors overdrive in a wagon with an automatic. I never saw under the car so I'm not sure how much massaging was necessary to get it to fit. I remember he said he was using the factory frame and the tunnel wasn't moved. He admitted some modifications were necessary but claimed they weren't crazy. Of course we all have different versions of what is or isn't a big modification.
Sadly I don't have contact information for the fellow. More annoying I typically only see him and the car once or twice a year.
The good news is (at least in theory) it can be done.
1961 Impala mild custom build
Gofastwclass on YouTube
Why buy when you can build it better?
Nitroholic
Nitroholic
Loc: Out West In SoCal
Reg: 05-08-03
07-07-19 09:54 AM - Post#2770109
    In response to pvs409
I believe that if you have an x frame you use their kit which includes a long tailshaft adapter which places the Gearvendors unit on the backside of the X member.
https://www.gearvendors.com/hrgm4sm.html
'66 C-10 Short Fleetside Big Window
threeimpalas
Loc: Central Iowa
Reg: 02-21-02
07-09-19 09:53 AM - Post#2770280
    In response to Nitroholic
Such an extension wouldn't fit through the center of the X, and would result in an unusably short driveshaft. The "long" tailshaft housing sold by GearVendors isn't that long.
Sell the Muncie; replace it with a TKO or T56.
'58-62s and 348/409s
Edited by threeimpalas on 07-09-19 09:53 AM. Reason for edit: No reason given.
pvs409
pvs409
Reg: 01-10-05
07-09-19 10:00 PM - Post#2770346
    In response to threeimpalas
A TKO or T56 5 or 6 speed requires major modification to the tunnel in front of the seat on all 61 to 64 Chevys. (the entire factory tunnel from the firewall to the seat has to raised 2 to 3 inches to fit a TKO transmission)
A Richmond 5 speed or 6 speed will bolt right in without floor modifications -I have a Richmond 5 speed in my 62 SS 409. Also retained my factory 1962 Impala SS shift plate.
I will be installing one or 2 more Richmonds 5 speed transmissions in my cars.
2500 RPM at 70 mph vs 4000 RPM in my Muncie 4 speed cars.
Paul
Execution time: 0.118 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:40 PM
