Username Post: 60 Impala Steering Wheel        (Topic#357122)
Bilbob
Loc: Schodack Landing, NY 1215...
Reg: 07-26-18
07-05-19 03:26 PM - Post#2770006
Installing steering wheel in my 60. Manual says to follow 58 manual procedure. I have the 58 manual but missing chapter #4 on steering! Specifically, is there a sleeve/spacer that fits over the steering shaft? It would put pressure on the steering column upper bearing (with horn contact) and the bottom of the steering wheel. Maybe someone has the 58 procedure they would share. Thanks, Bill
ragtp66
Reg: 12-09-07
07-05-19 07:14 PM - Post#2770015
    In response to Bilbob
yes there is a sleeve that fits around the shaft its roughly 3/4" to 1" long and has a split lengthwise. Part number for 58 was 3742446.
Toys:
1987 Sea Ray Pachanga 22
Bilbob
Reg: 07-26-18
07-06-19 06:32 AM - Post#2770037
    In response to ragtp66
Thanks! Now all I have to do is find it!! Bill
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
07-06-19 03:49 PM - Post#2770071
When I ordered my new upper bearing a spring came with it but I wanted to use the sleeve but it wouldn’t work with the new bearing so I had to use the spring instead. Lamar
Attachment: IMG_3658.JPG (916.98 KB) 28 View(s)
Attachment: IMG_4239.JPG (776.76 KB) 32 View(s)
Execution time: 0.182 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:55 PM
