Username Post: NEED ADVICE-WIN. REGULATORS        (Topic#357101)
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
07-03-19 05:18 PM - Post#2769865
Need some info here. In the pic of the 2 RR win regulators, the one on the left is one I bought for the driver side. Its arm is a little different shape than the one on the right which I know is a pass. side RR regulator for a 47 convertible.
The close up is the crank stem of the one on the left. It has a small hole with a spring in it when I removed the crank, but of course, I lost it when I moved it. The spring is a little smaller than one that comes out of a ball point pen.
2 questions:
1. Does anyone know yr, make, model of the Left regulator?
2. Was the little spring that came out of the hole factory? or did someone add this?
ANY help appreciated!
Attachment: 47_CHEV_RR_WIN_REGULATORS_SMALL.jpg (51.01 KB) 19 View(s)
Attachment: RR_WIN_REG_UNKN_YR_DR_SIDE_SMALL.jpg (39.47 KB) 23 View(s)
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
07-06-19 12:32 PM - Post#2770061
    In response to Broo102
I don't recall seeing anything like that on my '42 when I had it apart. My guess is that it might put a little pressure on the crank to keep it from rattling. Of course if mine had them they may have been lost years ago.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
Broo102
Broo102
Reg: 09-30-14
07-07-19 11:52 AM - Post#2770116
    In response to Rustchips
Cleon
Thanks for the reply, I dont think the spring is factory either, but I had to ask just to see the responses.
I noticed the amount of teeth are different between the two. (my 47 has 40 teeth the other one has like 28)
I was think about putting the correct arm from a spare I have on the driver side regulator, not sure if it would wok though.
Bru
Thanks!
Bru
John 3:16
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
07-07-19 01:08 PM - Post#2770121
I would go ahead and switch the arms, and try it. Nothing to lose. The window may not have enough travel with just 28 teeth.
Cleon
1928 Chevy Coupe
1970 El Camino
Broo102
Broo102
Reg: 09-30-14
07-07-19 07:55 PM - Post#2770155
I see
Would I be able to crank the window if I used the P/S on the D/S? would it work only backward?
Thanks!
Bru
John 3:16
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
07-08-19 12:26 PM - Post#2770194
I don't know BRU, Try it and you will know for sure.
Cleon
1928 Chevy Coupe
1970 El Camino
Execution time: 0.158 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:59 PM
