Username Post: LS1 engine rebuild question        (Topic#357076)
BlackC10
Reg: 07-02-19
07-02-19 11:26 AM - Post#2769739
I am planning on freshening up a 1998 Camaro LS1 engine. I am hoping to just replace rod and main bearings,oil pump,cam & lifters,head gaskets and water pump. What else would you replace?
77chevy
77chevy
Loc: trusting earth to a boys ...
Reg: 01-26-01
07-07-19 04:56 PM - Post#2770145
    In response to BlackC10
Without know your intentions. If you have the money forged pistons. the hp pistons crack ringlands under hp increase
the 243 heads are a famous swap but that leaves problems with your coil mounts.
on your stock heads you have prybar lift points so you want to search for a good head gasket to keep the heads sealed.
I dislike the tq to yield bolts so arp for head bolts and balancer for my rebuild.
good luck on rebuild...
77chevy
77chevy
Reg: 01-26-01
07-07-19 05:03 PM - Post#2770147
oh forgot timing chain... summit has a replacement chain you can use with your stock timing chain sprockets.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
08-10-19 05:58 PM - Post#2772916
1) How does the engine run now? 2)What problems are you trying to correct? For example what is the goal for changing the cam?
Execution time: 0.086 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:06 AM
