Username Post: 90 Chevy camaro rs brake problems        (Topic#357071)
Mybluecam90
Loc: St.Louis Missouri
Reg: 07-01-19
07-02-19 12:51 AM - Post#2769708
I have a problem with the brakes on my car. My car has a leak at the brake fluid level sensor also known as the malfunction warning light ,it has to do with the proportioning valve for the drum brakes.I'm having a very hard time finding the right one. Any help would be appreciated.
paulo57509
Loc: CA
Reg: 07-18-00
08-02-19 04:01 PM - Post#2772268
    In response to Mybluecam90
Have you tried Hawks?
https://www.hawksmotorsports.com/
https://www.hawksmotorsports.com/1982-92-camaro-fi...
You might also check the flares under the brake line nuts. Sometimes the flares will crack if the nuts have been over tightened.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Execution time: 0.132 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:26 PM
