Username Post: Bluetooth update        (Topic#357064)
Senior Chevytalk Moderator
07-01-19 12:56 PM - Post#2769662
Finally added Bluetooth to BADBOW. No more missed calls. I could never hear the phone ring or vibrate while driving. Either the exhaust was too loud or the dual 12" woofers shook everything inside.
Pioneer X6800BT model.
Though I didn't install it, the previous two models made it easier. Wiring and dash holes were updated.
Up next: heater core bypass valve installation and auxiliary A/C fan installation.
Attachment: radio.jpg (46.57 KB) 16 View(s)
Bluetooth radio
Attachment: mic.jpg (48.72 KB) 18 View(s)
Phone mic installed on pillar.
Attachment: portable.jpg (42.42 KB) 19 View(s)
Portable A/C unit!!
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
07-02-19 04:59 PM - Post#2769765
Hope you are planning to post the installation process of the heater core bypass as I am interested in that. I installed an AC auxiliary fan in front of condenser last month. Have already used it a few times when using AC and gauge appears not to have changed much. As of now, my compressor is very noisy and do not use it. My AC tech is closed till after the 4th.
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
07-02-19 05:46 PM - Post#2769769
    In response to Liberty Valance
Liberty Valance,
I’ve been driving BADBOW since Sat. On Thur, I’ll take a few pics on where I plan to install it. I’ll post pics. If I have enough time, I’ll install it. It will let water circulate until it’s locked out. By lock out, I mean vacuum controlled or temporarily tied up. I have post started on it. I’ll up date my progress there.
What type of fan did you install? Which compressor are you running?
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
07-02-19 06:02 PM - Post#2769772
I installed a 10" fan on right side, centered, directly on condenser. Installed under dash switch so I can turn on/off. I am using a reman GM A6 compressor. Not sure of which one I will use till my AC tech and I can talk about options.
Mopar by Birth
Chevy by Choice
Edited by Liberty Valance on 07-02-19 06:02 PM. Reason for edit: No reason given.
07-03-19 03:07 AM - Post#2769791
Ask if he can install a Sanden HD7
https://www.sanden.com/shd.html
I installed two. One in each of my Jimmys. The compressor uses 7 pistons to move R134. It's used on diesel trucks that turn lower RPMs. They work great! I recommend them. Once my current R4 blows up again, I'm converting to an HD7. Modifying my current hoses will cost about $100.
Are you using a cross flow condenser?
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
07-03-19 05:16 AM - Post#2769807
Worth checking into that compressor. I am not sure about condenser. He installed new 2 years ago. Will find that out next week.
Mopar by Birth
Chevy by Choice
07-03-19 05:27 AM - Post#2769810
A conversion kit is available for an A6.
Can you post or send me a few pics? I'm curious on the fan installation. I can probably tell what type of condenser is installed by looking at the tubing.
As for an optional fan, a Spal slim fan is my recommendation. I'm installing a GM replacement due to the brackets included. If the fan is not enough, I'll upgrade to a Spal and use the same mounting brackets. Worst case, I'll have to use the dual LS1 fans and front condenser fan for a/c use.
The radiator condenser design is a huge problem on our trucks. By '88, GM solved the problem. The gap between the two was closed or "flapped off". Anyone using only the mechanical fan or pull through fan should cover up the gap for better a/c cooling.
Edited by gchemist on 07-03-19 05:31 AM. Reason for edit: No reason given.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
07-03-19 02:43 PM - Post#2769852
I will get pic in the next day or two. How would I close the space between radiator and condenser? I had my AC hoses replaced 2 years ago. Would my hoses need to be modified with the Sanden HD7?
Mopar by Birth
Chevy by Choice
07-04-19 05:01 PM - Post#2769947
GM used thick rubber strips to cover the gap. My plan is to grab rubber strips from a 88+ truck. The piece will be bigger but it's trimmable to fit.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
07-04-19 05:08 PM - Post#2769949
Can these strips be ordered somewhere?
Mopar by Birth
Chevy by Choice
07-16-19 03:17 AM - Post#2770802
Sorry, I have not found strips for our trucks. Dense water pipe insulation should work.
Here is a good tech tip: http://www.gmtips.com/3rd-degree/dox/tips/c ool/ac-...
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
07-18-19 09:12 PM - Post#2771036
A man after my own heart!!! I have a single 12 with an 800W Wolfenhag sub amp coupled with my Pioneer.
I don’t always listen to ‘80’s music, but when I do, so do my neighbors!!!
Greg
'00 Explorer XLT 4.0 V6 Auto
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
08-11-19 09:05 AM - Post#2772958
Any new updates on heater core bypass or auxiliary fan or closing gap between radiator/condenser?
Mopar by Birth
Chevy by Choice
08-11-19 11:11 AM - Post#2772965
Yes, the R4 is working well right now. I did catch it slipping the other day. So I checked the clutch gap. So far even in 90+ degree weather, cooling and A/C are working good with a dual fan LS1 set up. The fans are quieter since air is pulled through condenser and radiator. I had to fix my Nitro A/C system on Thur. It pulls to 40 degrees while driving. Hope BADBOW can do the same or better.
A new R4 replacement compressor is next. I bought an Sanden SD7HD with an R4 hose end plate. The hoses will bolt on. My only concern is one hose. The high pressure hose may be too short. The hoses are custom cut. My local shop even updated the drier. I'll be able to remove the lower "J" fitting. Instead, the hose will connect directly to the drier. I have all the parts minus an orifice tube. I won't have time to install it this week. Maybe next week. With planned updates it may take 2-3 days. Updates include: 100 amp relays (3), one for each fan, upgraded fuses, better wire routing and auxiliary fan install. All this plus the bypass valve.
The plus, a Sanden HD compressor can do 8000 RPMs. I'm afraid to go over 3000 RPMs right now. One hard pull to 5000+ RPMs blew up the last R4.
Execution time: 0.156 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:23 PM
