Username Post: installation tips for Bully-brand step bars        (Topic#357040)
deckeda
Reg: 08-13-18
06-30-19 02:01 PM - Post#2769590
This is for Bully brand, model BBS-1103 black side step bars. A pair comes in the box, about $50 on Amazon, https://www.amazon.com/gp/product/B0062IJOJ2 /ref=p...
I'd give you a picture of them on the truck if I had hosting space for images.
Or if this forum did ...
Without any of the wedges or extra brackets these line up with the '90s Chevy's space for them (refer to Group D instructions in the installation guide). I installed one pair on a 2-dr (regular cab) model.
You'll need a SHORT 1/4" drill bit or right-angle adapter for your drill, to create the top holes. And do SKIP the included Phillips head screws for the top holes. Get 5/16 x 1" lag bolts and just slowly work them in with your ratchet. You might want to use the extra included washers here, or not.
1/4" lag bolts almost work, but the holes you made with the 1/4" drill bit were probably less than perfect and so a 1/4" lag bolt or sheet screw will be too loose. Get your lag bolts snug but not super duper tight or else they, too, will begin to just spin. THEN tighten the main bolts/nuts at the bottom.
'89 C3500 dually 2WD, 4-sp (SM465)
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
07-01-19 07:24 AM - Post#2769624
    In response to deckeda
Actually, this site DOES have picture posting. You have to be a silver supporting member is all.
Attachment: my_truck_opt.jpg (76.26 KB) 42 View(s)
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
deckeda
Reg: 08-13-18
07-01-19 08:34 AM - Post#2769631
    In response to beagrizzly
Thanks for that link; I guess it's an information page about it (I don't have permission to read it, ironically.)
I see the membership info page here: https://www.chevytalk.org/membership1.html
Edited by deckeda on 07-01-19 08:39 AM. Reason for edit: No reason given.
07-02-19 08:47 PM - Post#2769778
Posting photos by Tony
29-41, 42-48, 49-54 Moderator
Execution time: 0.21 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:15 AM
