Username Post: 12 Tips for New Drivers That You Can’t Learn in a Driving School        (Topic#357032)
johnsmith342
Reg: 06-30-19
06-30-19 06:32 AM - Post#2769568
Even the most experienced drivers don’t always know all the subtleties or nuances that can make driving easier.
Bright Side explains how to feel at ease when driving, learn to avoid dangerous situations, and become a confident driver.
12. Check if all your mirrors are adjusted correctly.
© depositphotos © depositphotos
If your mirrors aren’t adjusted correctly, a blind spot appears. A blind spot is a part of the road that you can’t see, so you may miss a car traveling in an adjacent traffic lane. In order to eliminate blind spots, adjust your side-view mirrors so that you can’t see your car in them. To check if there is a blind spot, drive past another parked car in reverse, looking in your side-view mirror. As soon as it’s out of the picture, you should see it with your peripheral vision.
The rear-view mirror must be adjusted so that you can see the back window of your car entirely. When adjusting the mirrors, you should be in your normal driving position.
11. Learn to feel where the wheels are.
If you want to be able to avoid potholes on the road and not scratch your hubcaps when parking, you need to learn to feel where the wheels are. Take an empty plastic bottle, step on it with your foot, and put it on the road. Practice driving over it with your left and right front wheels in turn. Open the window to hear the bottle crunch.
10. Park guided by your windows and mirrors.
© Facebook
When perpendicular parking, stop once you see the curb under the side mirror. This way the distance between the car and the curb will be minimal, and you won’t scratch the bumper.
When parallel parking, make sure you don’t scratch the hubcaps. Stick a piece of colored duct tape to the bottom of the windshield. Stop once the mark matches the curb line. It’s better to parallel park in reverse: this way, the curb is visible in the side-view mirrors, so you won’t be too close to it.
9. Dry your brakes after driving through a puddle.
© depositphotos
Before even the smallest of puddles, you’d better slow down and go through it smoothly without maneuvering or changing speed. If you drive quickly, there is a chance of water getting into the ignition system and making the engine stall. Besides, aquaplaning might start — that’s when a car loses traction, and you lose control of it.
After passing a big puddle, don’t cut your engine, and don’t change your speed. Dry the brakes first: pressing the gas pedal, press the brake pedal a few times. Friction causes heat, so water evaporates from the brake pads.
8. Watch out for the maneuvers of taller cars in front of you.
© depositphotos
Watch out not only for the car right in front of you but also for those further down the road. Drivers of taller vehicles (truck and buses) see road situations much more clearly. If they start to change lanes all at once, it’s likely that they saw a car accident or a different kind of roadblock. Follow suit, and change lanes too.
7. If the car doesn’t start, turn the high beams on.
Sometimes in winter the car just won’t start on the first try. Before you give it a try, heat your car battery by turning the high beams on. The radio or the indicator can work too.
6. Lower your rear-view mirror at night.
© depositphotos
Many drivers don’t know that a standard rear-view mirror has 2 modes: day mode and night mode. To avoid being blinded by a car behind you, change the angle of the mirror by pulling down the lever under it.
5. Turn on the air conditioner.
Even when you don’t use the air conditioner (for example, in winter), turn it on regularly for a short period of time. Otherwise, the coolant will seep out, and the tubes will be dry.
4. Use the hand brake regularly.
© depositphotos
Even if you don’t do angle parking, use the hand brake regularly to keep it alive. The only exception is very cold weather. In such conditions, you’d better avoid using the hand brake so that the brake pads don’t freeze.
3. If a car in the neighboring lane is slowing down, follow suit.
© Facebook
If you see a car in the neighboring lane slowing down, you should do the same. It’s likely that the driver wants to let a pedestrian or an animal pass.
2. Don’t let the illusion of low speed deceive you.
On a straight road, the speed seems to be 2 times lower than it really is. If you don’t slow down before making a turn, the car may begin to skid.
1. Don’t turn the wheels beforehand when making a left turn.
It’s dangerous to turn the wheels in advance before making a left turn. They must be in the initial position. If a car hits you from the back, you might be thrown into the opposite lane where hitting other cars will be inevitable.
Edited by johnsmith342 on 08-04-19 09:50 AM. Reason for edit: No reason given.
Execution time: 0.093 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:22 PM
