Username Post: No steering assist after steering-gear-swap.        (Topic#357025)
chevrolet_kelowna
chevrolet_kelowna
Loc: Kelowna BC
Reg: 11-23-07
06-29-19 06:12 PM - Post#2769535
Put in an AC Delco reman steering-gear, pitman arm and idler arm.
Topped the fluid to full cold started the truck, suck it down, topped it up. Did this over and over again.
Tons of bubbles, had some whining from the pump, topped it up. Took it for a drive and felt kinda wonky but still had good power steering assist.
Brought it back, top it up and then F'N assist stop working.
Fluid is topped, no whining anymore but, only have strong-arm-steering!!!
Pump gone now maybe?
Going to take it to a mechanic and have him put maybe a new pump in. They are cheap enough at $100 or so.
junky
Loc: Northeast CT
Reg: 06-27-10
06-29-19 06:39 PM - Post#2769540
    In response to chevrolet_kelowna
The reman steering boxes are junk. I got 3 in a row that didn't work. I bought all from RockAuto.com. After the third one, I found a company called PowerSteering.com and it worked flawlessly out of the box. Not the least expensive but worth every penny! http://www.powersteering.com/power-steering-gearbo ...
chevrolet_kelowna
chevrolet_kelowna
Loc: Kelowna BC
Reg: 11-23-07
06-29-19 09:49 PM - Post#2769552
    In response to junky
Damn really, that steering gear is like a 4 hour job the 1st time. I'm sure I could do an hour out/an hour in now.
How did you determine the steering box was junk and not the pump?
ACDELCO 36G0121 {#19321376} (Remanufactured) Professional; Remanufactured Info
GAS; Power Steering; w/ 8600lb. GVW (C6P)
Wasnm't cheap $345.00 then gotta send the core back.
06-30-19 04:40 AM - Post#2769561
Test the pump pressure first.
454cid
Loc: West Michigan
Reg: 02-18-12
07-07-19 02:39 PM - Post#2770135
The proper way to bleed a steering system is to have the front on jackstands and work the steering back and forth. Someotherguy has posted the specifics before. I think it was in the form of a TSB.
Also my ACDelco reman steering box has been short lived. It's still in service but it only lasted a few years before it started developing slop.
99 K3500 RCLB
chevrolet_kelowna
chevrolet_kelowna
Loc: Kelowna BC
Reg: 11-23-07
07-16-19 10:50 PM - Post#2770878
    In response to 454cid
UPDATE:
Took the truck to the mechanic, right away calls back and says the new/reman steering gear is crap.
Changes it and turns out it was the power steering pump.
We should have only turned the truck on for 1 second for it to suck down the fluid. Instead we just kept the truck running and adding fluid.
At one point the pump started whining, even though it had fluid, then quit during the procedure.
I would suggest reading the step-by-step procedure in the Chilton Manual regarding bleeding the power steering pump.
Edited by chevrolet_kelowna on 07-23-19 08:27 PM. Reason for edit: No reason given.
Execution time: 0.181 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:22 PM
