Username Post: Engine numbers help please        (Topic#357016)
65 Chev in NZ
Reg: 06-28-19
06-29-19 12:15 AM - Post#2769491
I have a 283 in my SS Impala and I am trying to find out more information about it. I beleave it is the original numbers motor. The numbers on the back of the block is 3849852 and D265, and the front of the block is F0504GF, the heads are 3795896. I have found details on the heads and block, althoug I am not sure about the D265.How do I find details about what the number on the front of the block means. Can anyone help with where to find this info please??
rick1965
Loc: joliet ill
Reg: 12-07-16
06-29-19 05:23 AM - Post#2769497
    In response to 65 Chev in NZ
letter f in the sequence stands for flint mich. foundry where the block was cast, 05 04 stands for casting date which would be may 4th 1965 g means 283 and f ending the sequence means there was a powerglide trans behind it.
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
06-29-19 06:22 AM - Post#2769500
Welcome to Chevy Talk! Lots of good info here. You want to get into the reference section as soon as you can.
Is your car a right hand drive? If so, I believe it is Canadian built and may have slight variations in what follows for the front of the block stamping. Each engine had letters/numbers stamped into a pad on the passenger side cylinder deck when the engine was mated to the body. These are visible in front of the head. The “F” should represent the manufacturing plant for the car. The numbers represent the last digits of your VIN. The last letters represent the transmission bolted to the engine at the factory. I don’t have my resources at hand but am betting others will chime in with the F and GP decoding.
The long numbers beginning with 3 on the block and heads are GM part numbers. The “D265” represents the date the block was cast. It decodes as D=April, 26th day, 5=65. This is a valid date code for a 65 block. Later in the year would put it in to the 66 model run.
The quickest way to confirm originality is to compare the block stamping against your VIN. Good luck on it being original.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
65 Chev in NZ
Reg: 06-28-19
06-30-19 12:47 AM - Post#2769553
    In response to Gaspains
That is great, thanx for your reply.
65 Chev in NZ
Reg: 06-28-19
06-30-19 12:48 AM - Post#2769554
    In response to rick1965
Thanx for your reply, it is a great help.
65 Chev in NZ
Reg: 06-28-19
06-30-19 12:50 AM - Post#2769555
Sorry,my car is a left hand drive. Everything I have so far says it is all mtching numbers, just trying to cross check. thanx for your reply is is helpful. I am new to this stuff.
centsless
centsless
Loc: Forest Hill MD
Reg: 10-28-13
07-04-19 04:14 PM - Post#2769942
I know for 1966 the VIN was not stamped in the block unless the engine was rated at more than 300 HP. The 283 was only rated at 195 and 220 HP. I think the best you can do is verify that the engine is "date correct". If the engine block and heads production dates are earlier than the vehicle production date, then chances are that it is the original. Usually what I have seen is that the engine date is a month or two prior to the vehicle build date, and the heads are a few weeks prior to the engine. Sorry its not definite, but it should be close.
"GF" is a 1965 Impala 283/195HP 2 barrel carb and powerglide.
My 1966 Caprice was missing its original 327, and I was fortunate to find a block that is 5 weeks earlier than the car. I am not building a chalk and crayon restoration, but it was cool to find a block that close to the original.
Bob
66 Impala convertible
66 Biscayne 427 2 door post
66 Caprice 4 door hardtop
66 Caprice 2 door
81 Corvette
96 DGGM Impala SS
01 S10
15 Silverado
2003 Crown Victoria LX Sport "Icky Vicky"
1965-66 FSCC member #530
Edited by centsless on 07-04-19 04:19 PM. Reason for edit: No reason given.
centsless
centsless
Loc: Forest Hill MD
Reg: 10-28-13
07-04-19 04:25 PM - Post#2769943
    In response to centsless
F is Flint Michigan plant
0504 May 4th
GF 283/195HP 2 barrel carb, pg transmission
D265 April 26, 1965
So the engine block was cast on April 26,1965 in Flint, and was assembled on May 4th of 1965
Hope that is a little better!
Bob
66 Caprice 2 door
81 Corvette
96 DGGM Impala SS
01 S10
15 Silverado
docjns1
Gold Supporting Member
docjns1
Loc: upstate NY
Reg: 11-12-19
11-12-19 09:13 PM - Post#2780083
If you're lucky enough to have a build sheet the engine code will be on it ( far left, 2nd row) and should match the last 2 letters stamped into the block. While I was fortunate enough to have a build sheet included with the documentation when I bought my '65 a while back, I also found another copy attached to the back of the driver's side lower 1/4 trim panel (usually they're under a seat between the springs) If your interior panels are original you may find one there!
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
59fins
Member #212 "19th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
11-14-19 08:25 AM - Post#2780139
My 67 was built 1st week of June 67, block and all other parts are dated H 26 66 all engine parts, and the POP verify's it on the numbers stamped on block, it was a 283, still have it.
Soon to sell, as I need the room! had it rebuilt, .020 over on pistons and .010 on crank, then about a year later went with a 290 - 295? hp crate offered by GM to fit our old cars pulleys, and brackets ... soon to sell it too, going to try the BB leap, car was a 77k car when I got it in 07, the engine was all original, but the trans .... someone stuck a T-400 in it, guess they had one lying around? car has 89900 on it now.
Anyways, dates are not always what they say they are, Warren has said he had seen this before on 283's as they may of been built in surplus?
Bill H.
67 Impala SS
toro455
toro455
Loc: Western NY
Reg: 06-15-02
11-28-19 08:22 AM - Post#2781174
    In response to 59fins
Bill,
Not all of the GM plants were great at FIFO (First In First Out). That would mean that you could have an older date coded motor in something; more date separation than you may think is logical. Possibly that's what Warren meant.
Scott
59fins
59fins
Reg: 04-07-00
12-03-19 07:18 PM - Post#2781464
    In response to toro455
I am sure it was probably first in the back of the building and last out
Most of the parts were cast about a day or three before it was put together can see the block says H276 on the rear next to the casting number, was in Colvin's book by the numbers the other day and it says that not much is known about this block #3896948
I'm sure because it is a 283
Attachment: HPIM2887.JPG (117.31 KB) 2 View(s)
Attachment: DSC04371...jpg (356.92 KB) 2 View(s)
Attachment: IMG_7825.jpeg (2.65 MB) 4 View(s)
Bill H.
67 Impala SS
Execution time: 0.139 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:36 AM
