Username Post: Rear Seat Belts        (Topic#357006)
hdcolo
Loc: Colorado
Reg: 08-04-17
06-28-19 01:13 PM - Post#2769449
. . Good morning, , Finished the hydraulic cylinder repairs for my top and decided this would be a good time to install the rear seat belts I bought five years ago. . I was expecting to see hard mounts on the floor but nothing to mount the seat belts to. . I don't have a problem drilling and putting a plate on the back side. . Just curious if there is a preferred spot to install them. .
. . '65 Impala SS Convertible
"16th Year" Platinum Supporting Member & Senior Moderator
06-28-19 01:53 PM - Post#2769455
    In response to hdcolo
Working from memory, which isn't as good as it used to be, I believe there are "dimples" where the holes were meant to be drilled. Make sure you use Grade 8 hardware since lower grade hardware won't handle the stress of a collision.
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
06-28-19 03:13 PM - Post#2769465
    In response to 427SS65
The accessory install manual in the reference section has good instructions. Including proper use. 😀
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
06-28-19 03:57 PM - Post#2769471
    In response to Gaspains
You would think I would have remembered that, since I was the one who posted it!
hdcolo
Loc: Colorado
Reg: 08-04-17
06-30-19 02:56 PM - Post#2769598
. . Found them, Thank you. . They were hard to spot, more like pimples than dimples. . Noticed square pads formed in the floor pan and then spotted the little tiny "dimples" in the center of each. .
06-30-19 03:36 PM - Post#2769601
Glad you found them!
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
07-03-19 06:32 AM - Post#2769814
More important than using high strength bolts is to use at least a thick, large washer to prevent the nut from ripping through the sheet metal in a collision. Here's some photos of what the stock pieces look like. They're spot welded to the floor.
Attached are some photos of the sheet metal I just replaced. The new floors came with the seat belt attachments already welded in, so if you want the correct attachment nuts, I'd ship them to you for the price of postage.
Attachment: IMG_20190703_064313.jpg (446.76 KB) 14 View(s)
Attachment: IMG_20190703_064254.jpg (327.08 KB) 6 View(s)
Execution time: 0.158 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:38 PM
