Username Post: Small Block Chevy with turbo 400 mounting        (Topic#356923)
New2the48
Reg: 06-20-19
06-22-19 05:05 PM - Post#2769005
Has anybody put a sbc with a turbo 400 in a 48 fleetmaster? If so how did you mount the transmission and engine?
06-22-19 05:52 PM - Post#2769007
    In response to New2the48
Welcome to ChevyTalk
29-41, 42-48, 49-54 Moderator
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
06-22-19 06:48 PM - Post#2769011
Welcome to Chevy Talk. I put a sbc and Turbo 350 in my ‘46 Fleetmaster. I used motor mounts from Chassis Engineering, now part of Heidt’s. They bolt to the frame. I then cut out the middle of the cross member between the two k-member braces. I then made a removable cross member out of 1/4 inch plate that bolted in using the 4 holes in the K-member. The Turbo 350 trans mount ended up dead center in the plate. With a Turbo 400 you may have to put an extension on the rear of the plate. You will have to modify the trans tunnel to clear the 400 or a 350. Another option is to cut it the K member and put in a universal trans mount. Check out the Chassis Engineering stuff, makes putting in a V8 and auto trans pretty easy.
Edited by lofat46 on 06-22-19 06:49 PM. Reason for edit: No reason given.
New2the48
Reg: 06-20-19
06-23-19 12:17 PM - Post#2769067
    In response to lofat46
Thanks for the replys. I've looked into the chassis engineering stuff I'm thinking maybe a dropped crossmember might do the trick if not I got Powerglide on the shelf ready to go don't really want to start chopping the car up if I don't have to.
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
06-24-19 09:45 PM - Post#2769195
I installed a SBC in my 47 Convertible with T-10 4 speed. Trans took some doing!
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
lofat46
lofat46
Reg: 08-12-13
06-25-19 04:51 AM - Post#2769201
Unless you already have the T400, I would consider using a T350 or possibly a 200R4 overdrive trans. Both are smaller than the 400 so easier to fit and are plenty strong enough for a sbc. The 200R4 is a little longer than a 350.
Execution time: 0.152 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:08 PM
