Username Post: Smog pump removal        (Topic#356916)
Jrmaasen
Reg: 06-21-19
06-21-19 10:57 PM - Post#2768968
I removed smog system on 1985 350 in a van30 on a motor home now have backfire problem any ideas
Edited by Tony on 06-23-19 10:50 AM. Reason for edit: Moved post to correct forum:
Senior Chevytalk Moderator
06-25-19 07:26 AM - Post#2769213
    In response to Jrmaasen
Welcome to the site. The van is pushing unburned fuel out the exhaust. The smog pump added air to help burn off fumes. The ECM is still changing timing. Changing the timing will help. Do you know initial timing? You can change it 1 degree at a time until it stops backfiring.
Execution time: 0.09 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:47 PM
