Username Post: Fuel gauge not working properly        (Topic#356871)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
06-17-19 03:46 PM - Post#2768709
Hey guys I cleaned up the contacts for the tank and when I turn on the ignition the needle moves just a little bit. I have a full tank but the needle won't go past empty. Any ideas?
06-17-19 04:02 PM - Post#2768712
    In response to Eth727
The float may be cracked and filled with fuel.
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
06-17-19 06:11 PM - Post#2768720
Fellow member "raycow" posted this test for me for a fuel gage question. Ray has since passed away, RIP fellow member, and with his passing everyone has lost an unmeasurable amount of knowledge. If you have a full tank according to Ray, you should have a reading of something around 30 ohms. Here's the link: https://www.chevytalk.org/fusionbb/showpost.php?po...
Edited by PLS on 06-17-19 06:14 PM. Reason for edit: No reason given.
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
06-25-19 04:56 AM - Post#2769203
    In response to PLS
Ugh, sad, sad new. My condolences to his family and friends!!
Me
Execution time: 0.109 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:38 PM
