Username Post: coolant temp reading on 1956 truck        (Topic#356867)
Tim-3200
Reg: 06-11-19
06-17-19 12:01 PM - Post#2768693
My coolant temp reading has not been functioning. I tested the gauge by taking off the wire from the sending unit & it was full C when ignition was on and not touching anything and full H when I grounded it so I believe that tells me the gauge is ok.
The motor is a 235 from a Chevy 58-62 car, so I replaced the sending unit with a ACDelco G1852 Professional Engine Coolant Temperature Sensor
Now the gauge reads C at start up, but as soon as things start to get warm it pegs to all the way to H.
The truck isn’t overheating and there is no progression of the needle – it just pegs.
Any ideas to help me diagnose the issue?
monty56
monty56
Reg: 04-26-04
06-18-19 09:56 AM - Post#2768751
    In response to Tim-3200
I'm guessing that is the wrong type of temp sensor. The way to check is to disconnect the guage and use an ohmmeter on the sensor from cold to hot. If warm goes to near zero ohms thats the problem.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Tim-3200
Reg: 06-11-19
06-18-19 12:44 PM - Post#2768759
    In response to monty56
Thanks Monty, I'll follow that line
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
06-18-19 09:14 PM - Post#2768790
That sounds like a switch for a light instead of a gradual resistance needed for a gauge.
This link confirms it.
https://www.amazon.com/Acdelco-Coolant-Tempe rature...
This should be the correct one
https://www.classicchevy.com/chevy-water-temperatu ...
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
Edited by WagonMan on 06-18-19 09:23 PM. Reason for edit: Added links
Tim-3200
Reg: 06-11-19
07-03-19 09:48 AM - Post#2769821
    In response to WagonMan
Thank you for the link to this part!
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
07-09-19 06:37 PM - Post#2770333
Generally speaking the temp sensor for a gauge will have 1 terminal and sensors for idiot lights will have 2, one wire to the "cold" lamp and the other for the "hot" lamp.
For a gauge you need a 1 wire sender calibrated to work with that gauge. So if you have a newer engine, you still will want to use the sender from the original engine to match the original gauge.
Execution time: 0.225 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:23 AM
