Username Post: Steering Columns        (Topic#356843)
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
06-16-19 09:48 AM - Post#2768568
Other than the tilt wheel columns, is there any difference between 61 thru 64 steering columns? And has anyone made the conversion to electric power steering?
Tom
1963 Chevrolet ?
$121.00
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
06-16-19 11:13 AM - Post#2768575
    In response to Swifster
there are 3 other columns in 61 to 64 - 4 speed columns, Powerglide columns, and 3 speed columns -all very different from each other.
A tilt column in 63 and 64 can come as a PG or 4 speed column, not sure on a 3 speed.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
06-16-19 11:21 AM - Post#2768577
    In response to pvs409
That makes sense. I guess my question is are all the Power Glide steering columns the same?
Tom
1963 Chevrolet ?
$121.00
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
06-16-19 01:20 PM - Post#2768586
Different guts, 61 & 62 I think are the same except maybe the location of the neutral safety switch? The signal light switch is attached to the column down on the column a ways. 63 and 64 are almost the same as each other, maybe different size hub on the steering wheels (64 bigger) and the signal light switch is inside the column at the top on both but the one for a 63 is a different part than the 64.
What are you trying to do or thinking of doing?
Member #2194
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
06-16-19 05:23 PM - Post#2768604
Here are 2 link's to my tilt column in my 64. I still have the standard column also with all the hardware and pieces for under the dash.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
06-16-19 06:11 PM - Post#2768611
    In response to DonSSDD
The '64 hub is smaller than the '63.
Verne
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
06-16-19 07:50 PM - Post#2768615
I'm thinking of cutting up a '63 column and installing electric power steering and getting rid of the hydraulic power steering completely. Power steering with no leaks and no worrying about taking up radiator space. The power units out of a Prius would slide in under the dash.
p.s., as much as I'd like factory tilt, I don't have the cojones to section one. If I was going to, I'd get an Ididit column.
Tom
1963 Chevrolet ?
$121.00
Edited by Swifster on 06-16-19 08:09 PM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Reg: 08-21-01
06-17-19 02:21 AM - Post#2768620
No idea how electric power steering works but while adding Prius parts, maybe add the hybrid power too?
Member #2194
lone star
Reg: 08-24-08
06-17-19 02:28 AM - Post#2768621
You can have hydraulic assisted power steering without leaks. Dont put a prius steering setup in anything
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
06-17-19 06:10 AM - Post#2768653
    In response to lone star
Just about every new car has electric power steering. The Prius unit works as a stand alone unit. Many of the GM units need a secondary module to power the computer. 90% of these units are made by the same company, even if they are in a Toyota, a Chevy, etc. The benefits are...
1) Frees up horsepower (no pump to spin)
2) Cuts weight from the pump, hydraulics and hoses
3) No interference with the radiator in a conversion
I haven't made a decision yet, but I'll probably get a used column and do a little experimenting. I can get the EPS at a pick & pull lot. for under $200.
Tom
1963 Chevrolet ?
$121.00
Edited by Swifster on 06-17-19 06:12 AM. Reason for edit: No reason given.
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
06-17-19 08:03 AM - Post#2768672
I, too am interested IN EPAS for my 62 Impala, but pretty much nixed the idea due to lack of real estate under the dash or in the engine compartment. Mine is a 4 speed manual car.
threeimpalas
Loc: Central Iowa
Reg: 02-21-02
06-17-19 01:11 PM - Post#2768701
You should keep in mind the differences in weight, wheelbase, tire width, and steering system type when thinking about integrating an electric power steering unit from a vehicle such as a Prius into a 60's Chevrolet.
'58-62s and 348/409s
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
06-17-19 07:29 PM - Post#2768726
    In response to threeimpalas
3450 lbs - 1963 Impala Sport Sedan
3050 lbs - 2007 Prius
3400 lbs - 2018 Malibu
3867 lbs - 2018 Impala
3627 lbs - 2018 Camaro conv
Every one of these cars (other than the vintage Impala) use the same power steering motor. Some are mounted on the column and some are mounted on the rack. The system from EPAS uses the same motor. The ONLY reason to use the Toyota motor vs the GM motor is that the computer is a stand alone unit. The GM unit needs a bypass module that is available on Ebay.
If the system fails, it just reverts to manual steering. I would rather have this unit on the column. The motor can be 'clocked' to move the motor where you want it. Some things may need to be moved or modified. That I'm sure I can do.
The EPAS kit runs about $1500. I can get the Toyota unit at a pick & pull for $150-200.
I have committed to nothing. I ask questions to be better informed. The car will be a restomod. The engine will be a 5.3L with a 4L60E. I'm using the car for work. I'll probably put 30,000 miles a year on it.
Tom
1963 Chevrolet ?
$121.00
cowfarmer350
Reg: 02-03-01
06-18-19 02:48 PM - Post#2768775
Another way of doing it, a few people over here are doing
https://m.youtube.com/watch?v=Yy6oQPJJ2qY&a mp;feat...
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
06-18-19 05:19 PM - Post#2768782
    In response to cowfarmer350
This is the set up for electric power steering using a used Prius/Corolla steering motor. Unlike the OZ video, this has no hydraulics. To me, using a fluid pump defeats the purpose of using electricity. The Toyota and Nissan units have separate computer modules.
Again, I'm looking at doing a restomod, not a restoration. The system does require a 60 AMP circuit/fuse for when the steering wheel is at full lock. At center or just off center, the current draw is minimal.
This type of system means I can use a base Impala manual steering system. I don't have to replace the steering box. I don't need to use the control valve, the hoses or the ram. I don't need fluid, a reservoir or a pump. I don't have to use the 4-9 HP the pump takes from the engine. There is nothing to leak...ever. No bump steer issues. No trying to squeeze stuff to fit (except under the dash). No radiator modifications.
I thank you guys for the steering column info. I'm sure I can dig up a used Power Glide steering column and rebuild it with the motor.
Part 1 - https://www.youtube.com/watch?v=f4TYQ_KJSpc
Part 2 - https://www.youtube.com/watch?v=cERfqzKfoAk
Part 3 - https://www.youtube.com/watch?v=JAE1D70MHgk&a mp;t=...
Part 4 - https://www.youtube.com/watch?v=lDGjRSHUj1g
Tom
1963 Chevrolet ?
$121.00
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
06-18-19 06:13 PM - Post#2768786
I say give it a whirl. The EPAS system has been used in the vintage mustangs for a couple years. It seems to work well and as you said it reverts to manual if there is an issue.
Its not original but it is hotrodding.
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
DonSSDD
DonSSDD
Reg: 08-21-01
11-19-19 01:57 AM - Post#2780478
    In response to Original58
OP, did you ever do this conversion, curious what happened.
Member #2194
Execution time: 0.108 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:44 AM
