Username Post: Rochester B Carb question        (Topic#356832)
carolina chevrolet
Reg: 11-12-18
06-15-19 03:10 PM - Post#2768520
I am having trouble a Rochester B Carb, can't get gas to spray into the throat. New rebuild kit, float bowl is nearly full of gas but the bowl gasket is covering the little T , spring and check ball. Is the gasket suppose to cover that up ? I can't see how gas suppose to get from the accelerator pump into the carb body. With the carb separated and gasket removed I can work the pump and see gas squirt up by the ball, spring and tee. The kit came with 2 gaskets and they both cover the tee.
2blu52
2blu52
Reg: 03-12-02
06-15-19 03:48 PM - Post#2768521
    In response to carolina chevrolet
Most rebuild kits have two bowl gaskets in them, one for the manual choke and one for the automatic choke. the More open gasket is the one that fits the B, the closed one is for the BC. If the wrong one is used then the problem you describe can occur. I would post a picture of the correct gasket but after nearly 20 years on this format I still have not mastered that.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
06-16-19 04:46 AM - Post#2768540
This exploded view shows a couple holes in the gasket where the accelerator pump is. Hope this helps
You might also temporarily assemble with no gasket and see if it changes. Obviously it will leak so I don’t mean install it.
Assuming there are holes on the bottom and top halves, there most likely should be in the gasket as well
Attachment: 6BE725F0-53D6-4CFA-A521-21DA074873F4.jpeg (157.19 KB) 15 View(s)
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Edited by drew1987 on 06-16-19 04:47 AM. Reason for edit: No reason given.
carolina chevrolet
Reg: 11-12-18
06-16-19 05:29 AM - Post#2768543
    In response to drew1987
Evidently gas is not suppose to come up, but go down. There is no hole in the bowl cover to match the hole where the tee, spring and ball are. Still can't gas to make it thru the carb.
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
06-16-19 05:42 AM - Post#2768544
If the ball has fallen out, not been installed, or is the wrong size the accelerator pump will not work.
It certainly is possible for the passage to be blocked preventing the fuel to flow through the accelerator circuit also.
Just Slightly Abrasive
Edited by 40grit on 06-16-19 05:44 AM. Reason for edit: No reason given.
carolina chevrolet
Reg: 11-12-18
06-16-19 06:43 AM - Post#2768550
    In response to 40grit
"It certainly is possible for the passage to be blocked preventing the fuel to flow through the accelerator circuit also."
That's what I am now thinking. It has a new ball and spring, installed correctly and will squirt a stream of gas about a foot high when the pump is worked by hand with the cover off the float bowl.
2blu52
2blu52
Reg: 03-12-02
06-16-19 07:34 AM - Post#2768558
Is the exterior pump link properly assembled. Also there are two larger balls in a kit one is steel the other is aluminum the steel ball fits in the pump discharge, check the shop manual for that location. The diagram provided by Drew is for the BC model not the manual choke.
THOMAS JEFFERSON
Edited by 2blu52 on 06-16-19 07:35 AM. Reason for edit: No reason given.
carolina chevrolet
Reg: 11-12-18
06-16-19 05:38 PM - Post#2768608
    In response to 2blu52
Problem solved. Turns out that the little tee (35)that holds the spring (36)and ball(37)in place was turned 90 degrees from where it should have been. It was blocking the passage. I got to hear my '53 Belair run for the first time this evening.
Edited by carolina chevrolet on 06-16-19 05:39 PM. Reason for edit: No reason given.
drew1987
drew1987
Reg: 02-23-14
06-17-19 03:45 AM - Post#2768630
Awesome! That’s what it’s all about!!
Member:
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
06-20-19 03:15 AM - Post#2768868
Congrats on figuring that out!
Dean50
KoraB
Loc: Salt Lake City, Utah
Reg: 06-21-19
06-21-19 07:27 PM - Post#2768963
Mikes Carbureter on utube has vids and all the parts as well as rebuild kits for Rod. B carbs. Does it all, they are the best.
MB in SLC, UT.
drew1987
drew1987
Reg: 02-23-14
06-22-19 04:31 AM - Post#2768971
    In response to KoraB
I destroyed a little barrel shaped spring some years ago. Mike sent a couple new ones very inexpensively and quite promptly. Great guy
Member:
Execution time: 0.146 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:50 AM
