Username Post: Electrical check        (Topic#356821)
Bilbob
Loc: Schodack Landing, NY 1215...
Reg: 07-26-18
06-14-19 02:00 PM - Post#2768463
Got the 60 Impala wired according to manuals and hopefully all is correct! I'm afraid to power up with a 535amp battery in case there's a problem. I have a small 12 volt power pack that puts out 12v and 1 amp. I thought I'd power the system with this unit and check for 12volts in all the right places! Sound reasonable? Any suggestions about another method? Thanks Bill
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
06-14-19 02:09 PM - Post#2768464
    In response to Bilbob
I had the exact same question and here's the suggestion that I used even though my wiring was all new from AAW and it worked great but as noted you can't check the starter. https://www.chevytalk.org/fusionbb/showtopic.php?t... Lamar
Edited by PLS on 06-14-19 02:12 PM. Reason for edit: No reason given.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
06-17-19 04:23 AM - Post#2768627
That should work fine. I always use a battery charger set to a 2 amp charge. Just enough to check out the wiring but not enough to fry anything.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
Execution time: 9.153 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:13 AM
