Username Post: brake booster offset question for valve cover clearance        (Topic#356810)
df0rster
Reg: 10-25-18
06-13-19 12:49 PM - Post#2768389
Wondering if anyone has tried to offset their brake booster to fit standard valve covers? I want to use my Holly aluminum chevy valve covers on my big block but they don't quite fit with the power brake booster. I've seen mini boosters and some offset mounts but not really for the '67 Impala specifically. just wondering if this has come up on here with anyone.
Thanks!
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
06-13-19 04:56 PM - Post#2768404
    In response to df0rster
Well, 67's came with big blocks with "factory standard" valve covers. There was barely enough room for them. I have a 67 with a ZZ502 and their valve covers, and they barely clear. Holley aluminum are not standard. The only offset boosters I've ever heard of were on small body Mopars with Hemi's.
And you can't offset it unless you remove the wiper motor.
Attachment: P1040558.JPG (1.4 MB) 13 View(s)
Edited by sz0k30 on 06-13-19 04:58 PM. Reason for edit: No reason given.
06-13-19 05:44 PM - Post#2768408
How about a 7" double diaphragm booster?
59fins
Member #212 "20th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
06-14-19 10:17 AM - Post#2768449
I don't know, with that being said....
Did some of the old BB cars come with a notched valve cover for the brake booster like Camaro and Nova's? Not versed in this but seems to me they were on cars with p/brakes?,
And then does the 502 have roller rockers? if so then the valve covers are taller? if that is the case I would not mess with trying an offset, I think you may need double booster as mentioned.
https://www.ss396.com/camaro/XA-101S.html
this was what I was thinking but again, 502 may be different.
Apparently the the Holley valve covers once re-read your post, it puts a twist on it, that same site had them I believe and they looked huge.
Bill H.
67 SS
Edited by 59fins on 06-14-19 10:20 AM. Reason for edit: No reason given.
100 CHEVY
Deceased Member RIP
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
06-14-19 10:36 AM - Post#2768450
    In response to 59fins
I have the covers with the cut off corner on my 65.
I plan to change the booster to hydroboost sometime real soon,then I can use any valve cover.
Mike.
sz0k30
sz0k30
Reg: 10-12-08
06-15-19 07:48 AM - Post#2768502
    In response to 100 CHEVY
The 2nd post was my before.
This is my after.
Attachment: P1070924.JPG (644.34 KB) 13 View(s)
df0rster
Reg: 10-25-18
06-19-19 10:36 AM - Post#2768827
    In response to sz0k30
Thanks for the info! I like the looks of that hydroboost, but the 7" double booster might be easier and less expensive to use. I almost have enough room for the Holly valve covers already so I don't need much more.
Thanks again!
100 CHEVY
Deceased Member RIP
100 CHEVY
Reg: 12-09-04
06-19-19 03:56 PM - Post#2768845
Do you have any pics or details of your brake pedal to hydroboost mods?
It would help me a lot!
I have it in 3 of my trucks and love it!
Thanks,Mike.
sz0k30
sz0k30
Reg: 10-12-08
06-20-19 05:54 AM - Post#2768873
Hey Mike,
I used a hydroboost unit that I bought years ago off eBay that came off an M-van. Since my 67 had the original booster, the only thing I had to make sure was the same, was the length from the mounting surface to the clevis pin as shown in the photo.
The M-van had a much longer pushrod that I had to shorten and thread for a new clevis. The hard part was finding a short clevis. I finally found a Speedway Motors #916-31949 that I still had to shorten & modify.
Attachment: P1060801.JPG (592.33 KB) 10 View(s)
100 CHEVY
Deceased Member RIP
100 CHEVY
Reg: 12-09-04
06-20-19 06:17 AM - Post#2768878
That's what I needed to see!
Did you use the same hole in the brake arm for the clevis? Or,have to drill a new hole?
Thanks!
I have the same hydroboost unit for my 65.
Just a few months ago,I converted to a 67 dual master and new brake lines,so I'm ready to move forward with this.
I want to see how the hydroboost works with my drum brakes before I convert to disc.
Mike.
sz0k30
sz0k30
Reg: 10-12-08
06-20-19 12:08 PM - Post#2768896
If I remember correctly, the arm has two holes drilled in it. One for manual & one for power brakes. If you've power, use the same hole.
100 CHEVY
Deceased Member RIP
100 CHEVY
Reg: 12-09-04
06-20-19 05:45 PM - Post#2768909
Thanks again.
I think I have enough info to get it done now.
Mike.
wch
Loc: TX
Reg: 05-13-17
07-07-19 07:48 AM - Post#2770099
After having properly set up manual brakes I don't think I will ever go back. I love the feel of my set up,the extra room and no vacuum connection. In fact I am looking at doing this on my other car also now.
Casey
1966 Impala,2dr,283,PG,Wilwood brakes
1985 Chevrolet,C20,350,th400
1986 Chevrolet, Corvette,400ci Dart SHP,TH350
Edited by wch on 07-07-19 07:48 AM. Reason for edit: No reason given.
Execution time: 0.106 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:53 AM
