Username Post: Source for worm gear clamp on intake?        (Topic#356801)
Ray1
Reg: 12-05-03
06-12-19 11:15 PM - Post#2768355
This guy here at the throttle body - link
This is on the 4.8 V8.
Mine is worn out and won't tighten up anymore. I'm hoping this is not permanently affixed to the intake, I haven't really looked at it but it seems like it is stuck on good. It'd be great to hear the clamp can be replaced with a generic auto parts clamp.
Edited by Ray1 on 06-12-19 11:17 PM. Reason for edit: No reason given.
Senior Moderator
06-13-19 12:10 AM - Post#2768356
    In response to Ray1
Typically a clamp on an intake boot like that has a keyed slot in it that slides over a nub in the boot's rubber to keep it from slipping off; just takes rotating the clamp to slide it off the nub. You could use a regular clamp if you find one large enough to fit that isn't also too wide so that it doesn't smash the boot's lip.
I don't believe GM offers that specific clamp separately, but you could probably score it from a boneyard or from someone that has a stock air intake sitting around.
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
06-13-19 03:43 PM - Post#2768399
    In response to Ray1
MEASURE THE DIAMETER,YA PROABLY CAN USE A DRYER VENT CLAMP FROM 1 OF THE BOX STORES.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
06-13-19 05:02 PM - Post#2768405
    In response to TAT_2
Hell, that is a generic autoparts/hardware store clamp.
Senior Moderator
06-13-19 05:42 PM - Post#2768407
    In response to sz0k30
Nothing really unique other than the key slot I mentioned. Regular clamp won't have it so you'll need to modify slightly.
Ray1
Reg: 12-05-03
06-13-19 06:07 PM - Post#2768410
The quality is surely too low for that . . . this is the first time I've ever seen a worm gear clamp fail.
Ray1
Reg: 12-05-03
06-13-19 06:08 PM - Post#2768411
That's a possibility. I've measured the clamp size and will see what I can turn up.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-13-19 07:39 PM - Post#2768415
    In response to Ray1
Go to your local hardware store and you should be all set. looks to be around a 4"
And sadly I have seen worm clamps break.
I have seen ones that looked like new break,
but ones that were rusted badly but still holding.
I have seen a hoseclamp cause a blown engine.
Hoseclamp fails, hose pops off, and if driver doesn't pay attention thats all it takes.
Old School GM fan FOREVER
Ray1
Reg: 12-05-03
06-13-19 09:22 PM - Post#2768417
    In response to rockfangd
Well this clamp shouldn't be able to blow the engine thank goodness.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
06-14-19 04:45 AM - Post#2768425
    In response to Ray1
Looks to me like the screw for the clamp is backwards.
Senior Moderator
06-14-19 05:00 AM - Post#2768426
    In response to aghaga
Good catch. I think I looked at it on my phone previously and didn't see that. Sure does look like someone took it apart and tried putting it back in the wrong side.
Ray1
Reg: 12-05-03
06-14-19 08:57 PM - Post#2768489
    In response to someotherguy
I'd be that someone. It won't hurt me too much if all I have to do is put the screw on the other side.
edit - that fixed it!
Edited by Ray1 on 06-14-19 09:43 PM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
06-15-19 12:00 PM - Post#2768508
    In response to Ray1
Execution time: 0.195 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:45 AM
