Username Post: Changing Speedo Cable in 66 Biscayne        (Topic#356785)
jeff198901
Reg: 09-16-17
06-11-19 06:34 PM - Post#2768266
How hard is it to change out the speedometer cable in a 1966 biscayne?
My car has a tko600 transmission in it and I am pretty sure it has an adapter that is allowing it to run the original cable (from my knowledge its original.
Also, what is the process of lubricating a speedo cable?
Thank you!
Jeff
J260MikeN
Reg: 08-01-18
06-12-19 07:39 AM - Post#2768306
    In response to jeff198901
The hardest part is getting your hand up behind the dash to disconnect the cable from the speedometer. The rest is straight forward.
jeff198901
Reg: 09-16-17
06-12-19 08:04 AM - Post#2768309
    In response to J260MikeN
I was surprisingly able to get my hand up there and loosen the current cable off! Hopefully I can get the new one on just as easy!
J260MikeN
Reg: 08-01-18
06-13-19 07:34 AM - Post#2768370
You're most of the way there
Execution time: 0.104 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:17 AM
