Username Post: Air compressor start problems        (Topic#356776)
awsum55
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
06-11-19 09:43 AM - Post#2768225
My compressor stopped working the other day when I wasn’t using it, it has a slow leak, so it probably started up to replace air and blew a fuse. When I went to start it , it made a very loud buzzing noise and wouldn’t start, so I used youtube to find a solution.
The start capacitor was dead when I went to check it with my multimeter as instructed by the video. I purchased a new start capacitor, installed it and tested the motor while off the compressor for a split second and it started.
I read that start capacitors have no polarity but I had to remove a resistor from the old one and solder it to the new one. I was concerned that the resistor might have polarity that would make it important to install it in the right direction, but I couldn’t find anything that would tell me how to do it.
I put everything back together and hit the switch, this time it started and blew the circuit almost instantly.
I’m concerned that I might have hooked the wires up wrong, when I put the run capacitor back on after testing it. The start capacitor has 3 terminals and the wires attaching to it were all black. I can’t find any markings on the case that would tell me what each one was.
When I tested the run capacitor it was supposed to be 30mf plus or minus 6%. It was 28mf which is just slightly low. 6% of 30 is 28.2 so I knew it was a little low, but close enough I thought. Is .2mf enough to make the compressor not run and blow a fuse?
I’m kind of stuck on what to do next, do any of you have any advise on how to solve this?
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
07-04-19 10:20 AM - Post#2769926
    In response to awsum55
i do not think resistors have polarity like diodes. did you use a heat sink when soldering? did you check the motor brushes?
hilandr451
Moderator & "11th Year" Gold Supporting Member
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
07-09-19 10:27 AM - Post#2770285
Here's your problem Vern!
what we need to do is find a wiring diagram for your compressor motor (should be under the inspection cover where the power wiring is), make/model of your compressor and post some photos so we can see what we're dealing with. I'm confidant that we can get you back on line in no time!
(IMO: brushes wouldn't be a factor in this scenario since it started just fine when he "tested" the cap)
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L,
1966 C20 Custom Camper "Rattle can primer red" 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
65_Impala
Reg: 12-29-02
07-15-19 04:26 PM - Post#2770776
Did you check that the unloader is working?
Execution time: 0.089 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:21 PM
