 Page 2 of 2 <12
Username Post: 1953 Sport Coupe Sun Visor Brackets        (Topic#356756)
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
07-19-19 04:28 AM - Post#2771050
The 55-56-57 convertible sun visor hooks will not work on a 1953 hard top. I was hoping the opening of the hook would be wide enough for the edge of the sun visor but it is not.
Not giving up though. I will be continuing my search for some kind of bracket to hold up the end of my sun visor even if I have to make something myself. I'm sensing a trip to the hardware store...
Hmmm, just checked "brackets" on Ebay. Only 2.1 million to sort through.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
07-19-19 06:06 AM - Post#2771058
Vern,
If I'm not mistaken, the visor just slips off the rod. Why can't you just extend the rod an inch or so with the correct size for the hook? That is what GM did for the convertibles I think.
Just Slightly Abrasive
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
07-19-19 11:02 AM - Post#2771078
    In response to 40grit
The hard tops don't have a rod sticking out of the visor blade. The rod is fully enclosed.
Vern
40grit
40grit
Reg: 07-08-13
07-19-19 11:55 AM - Post#2771081
I understand that. But can you not take the visor off the rod, extend the rod, and re-install the visor. Extending the rod should be a ten minute job for any one with a MIG welder. The convertible just has a longer rod I think.
Dman1966
Loc: Canada
Reg: 09-10-17
07-19-19 10:12 PM - Post#2771121
I have my hardtop visors apart for reupholstering. The rod only goes halfway on the support side. If i can send a pic through someones email i can show. So you're right, no need for welding as you have 6 inches of a rod you can put in there. 1/4", 5/16th will do
40grit
40grit
Reg: 07-08-13
07-19-19 11:38 PM - Post#2771122
    In response to Dman1966
PM sent.
40grit
40grit
Reg: 07-08-13
07-20-19 05:14 PM - Post#2771174
Dman1966 sent these to me to post for him
Hi there John
Here's some pics. So the rod only goes halfway down on both of my visors. Now I'm not 100% sure these are original as i got the car half way done and mostly in pieces.
It's been two years of tinkering but almost complete (See last pic). Canadian 1037D.
So a nice chrome rounded rod from maybe a junkyard would slide in mine.
Cheers
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
07-21-19 01:43 AM - Post#2771201
Mine have been re-upholstered. I would not want to remove the upholstery to lengthen the rod.
Vern
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
07-22-19 01:58 AM - Post#2771261
Hey Ed, thanks for sending me those photos. I can seen now how different the visors are for convertibles vs hardtops.
Vern
eplantage
Loc: Southern MN
Reg: 03-15-04
07-22-19 03:32 AM - Post#2771263
You're welcome. Feel free to post them here if you would like to.
Age: 65 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
07-23-19 01:56 AM - Post#2771353
    In response to eplantage
Sure. This is a '53 Chevy convertible sun visor. You can see that there is a rod that sticks out at the end. The hard top visor is completely closed on the end.
Attachment: 53chevyconvisor.jpg (56.32 KB) 6 View(s)
Vern
Dman1966
Loc: Canada
Reg: 09-10-17
07-27-19 10:21 PM - Post#2771772
cool to see the slight differences in the models, and not just in a parts book.
40grit
40grit
Reg: 07-08-13
11-07-19 08:25 AM - Post#2779724
Vern, did you make the hooks work? Several of us would be interested in how you worked the visors out.
Edited by 40grit on 11-07-19 08:32 AM. Reason for edit: No reason given.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
11-08-19 05:38 AM - Post#2779766
Never got around to it. I have put my car up for the winter.
Vern
 Page 2 of 2 <12
Execution time: 0.101 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:02 PM
