Username Post: Clutch return spring        (Topic#356748)
Coupe50
Coupe50
Loc: Sweden
Reg: 04-27-14
06-09-19 11:59 PM - Post#2768080
Is the clutch return spring mounted with some slack or is it mounted tight. I have the version that you have to cut the spring to the right lenght by yourself. Carla.
bobt
Loc: colonial heights va
Reg: 06-28-14
06-10-19 02:57 AM - Post#2768083
    In response to Coupe50
mine is mounted tight. 1951 Fleetline.
Coupe50
Coupe50
Loc: Sweden
Reg: 04-27-14
06-10-19 06:12 PM - Post#2768177
    In response to bobt
Ok. Thank's. Carla.
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
06-11-19 08:26 AM - Post#2768216
Be sure it is tight enough and placed in a position that it pulls the clutch arm at the bell housing hard enough to raise the clutch pedal to it's upper stop.
The purpose is to pull the throw out bearing away from the pressure plate to prevent premature throw out bearing failure. If the clutch is adjusted properly, with the spring on you should have about 1" of free travel in the clutch pedal.
Just Slightly Abrasive
Coupe50
Coupe50
Loc: Sweden
Reg: 04-27-14
06-12-19 01:57 AM - Post#2768286
    In response to 40grit
Thank's for the info. I think the best for me here is to stretch the spring a little and see where i should cut it.Carla.
bobt
Reg: 06-28-14
06-12-19 03:14 AM - Post#2768288
Make sure you have the right spring. It should be very strong.
Coupe50
Coupe50
Loc: Sweden
Reg: 04-27-14
06-12-19 02:20 PM - Post#2768333
    In response to bobt
I bought it from Chev's of the 40's. No one have the original style so i have to cut it to the right lenght and bend it.
Execution time: 0.07 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:18 AM
