Username Post: freeze plug        (Topic#356747)
badbob85037
Loc: Arizona
Reg: 03-13-09
06-09-19 09:45 PM - Post#2768079
Does anyone have a fix for an over sized hole for a freeze plug?
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
06-10-19 01:21 PM - Post#2768143
    In response to badbob85037
https://www.amazon.com/Dorman-Autograde-570- 007-1-...
Attachment: rubber_plug.png (19.91 KB) 10 View(s)
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-10-19 01:21 PM - Post#2768144
what size is the hole and what size freeze plug are you trying to use that won,t seal correctly?
is the block walls in the freeze plug hole in the block distorted, damaged or rusted badly?
yes rubber expansion freeze plugs can be an option
rubber expansion freeze plugs come in a wide selection of various diameters
Edited by grumpyvette on 06-10-19 01:25 PM. Reason for edit: No reason given.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
06-12-19 07:54 PM - Post#2768353
    In response to grumpyvette
You can get those at Napa...today, versus having to wait on amazon.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-13-19 05:19 AM - Post#2768365
    In response to Stinky
yes and advance auto and other vendors
measure the hole your trying to plug accurately
clean the block carefully before you install the plug
coat the block and freeze plug contact surfaces with sealant just prior to install
Edited by grumpyvette on 06-13-19 05:27 AM. Reason for edit: No reason given.
Execution time: 0.174 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:45 AM
