Airlifter
Reg: 06-07-15
06-09-19 03:16 PM - Post#2768063
I would like to buy a mig welder but I can't justify the price of the Lincoln and Miller welders. I have been looking at the ones at harbor freight. Does anyone have any experience with these welders<
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide |
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-10-19 07:17 AM - Post#2768107
In response to Airlifter
Ive had several friends purchase welders from HF,
the results vary considerably , my B.I.L. purchased both the 90 amp rated flux core
(returned it as worthless, after a 24 hour trial, )
he bought a $289 flux core mig ,
and also returned that after a short test,
and it should be obvious that a decent MIG welder even a rather cheaper versions will work fairly well,
he bought a lincoln mig later, and has had zero issues with it,
https://www.northerntool.com/shop/tools/product_20 ...
as with most things you tend to GET WHAT YOU PAY FOR,
QUALITY COSTS MORE
while not always true ,because designs and components differ higher WEIGHT is also an indicator of better quality
anything much under about $400-$500 is not going to be high quality and good for decades of trouble free use with only minor maintenance,
but theres a huge difference between a cheap FLUX CORE welder and a decent lower cost MIG welder... MIG WELDING REQUIRES USE OF A TANK OF SHIELD GAS AND GAS REGULATOR
hobart, lincoln, eastwood and other vendors also sell lower cost MIG welders , youll want to decide on if youll be reasonably well served with a 110 volt 140 amp mig or need something with more capacity,
understand DUTY CYCLE, if a welder says 30% duty cycle at x amps its means you weld for 3 minutes and let cool for 7 minutes before it can be used again, lower amps generally allow higher duty cycle,
anything that almost any welder advertises, that says FLUX CORE is not going too be high quality mig.
why not visit a local lincoln dealer and ask questions
the eastwood welders have a decent reputation
https://bestweldinghelmet .review/mig-welders/
https://weldingpros.net/best-mig-welder-revie ws/
http://www.kingsofwelding.com/buyers-guides/best-m...
https://www.drillpressview.com/best-mig-welder/
https://www.amazon.com/dp/B005CNOVZU/?creati veASIN...
https://www.harborfreight.com/migmax-140-industria...
https://www.farmandfleet.com/products/693798-linco ...
https://www.eastwood.com/eastwood-mig-welder-1 75-a...
https://www.eastwood.com/eastwood-mp200i.html
https://www.harborfreight.com/search?q=mig%20welde...
https://www.eastwood.com/welders/mig-welders.html
https://weldingdirect.com/migwe11mama.html
https://www.lincolnelectric.com/en-us/equipment/mi...
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!! |
Edited by grumpyvette on 06-10-19 01:52 PM. Reason for edit: No reason given.
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-10-19 09:13 AM - Post#2768119
In response to grumpyvette
a couple hours reading linked info could easily save you hundreds of dollars and days of problem solving,
Id point out that decent quality, 110 volt 120 amp mig will do a decent job on sheet metal,
but most are limited to work on under 3/16" thick metal and thats really pushing the limits,
now that may be on a 20-30% duty cycle, that requires you to weld 2-3 minutes and let the welder cool 7-8 minutes between welds
if you spent a bit more you get a 220 volt 180 amp-210 amp welder , if used at the amps required for sheet metal , duty cycle is far higher
maybe at 70% so you weld for 6-7 minutes and let cool for 3-4 minutes.
you rarely weld for more than a minute or two, so in reality, you can use the 180-210 amp rated migs almost constantly
if used on the lower amp settings
go a bit excessive, get a 230-250 amp mig and your duty cycles high enough that you ignore duty cycle limitations
yes Im a tool junky
I don,t know how anyone in this hobby can get by without a decent welder.
no you don,t need anything near the cost of a miller 252 mig but I would certainly ;look at the hobart,eastwood,lincoln migs in the links and strongly consider spending $500-$800 on a higher quality mig that should last for decades and select a brand where parts are likely too be available in 4-6 years
this miller 252 migs been damn useful, and its most likely the most practical choice,but I've found I use both a MIG and TIG and occasionally an ARC welder.
if limited to a single welder I think it would be a 250-300 amp range TIG with a water cooled torch, and easy switch adjustable polarity, adjustable frequency, and amps (yes the foot petal works on my tig
Duty cycle is a welding equipment specification which defines the number of minutes, within a 10 minute period, during which a given welder can safely produce a particular welding current. For example, a 150 amp.welder with a 30% duty cycle must be "rested" for at least 7 minutes after 3 minutes of continuous welding.
you NEED a tank of shield gas to MIG WELD CORRECTLY, you rent those tanks with a healthy deposit or buy and have the tanks refilled and re-certified every few years
https://www.eastwood.com/mig-250-welder-eastwo od.h...
https://www.northerntool.com/shop/t...devicetype=c...
Edited by grumpyvette on 06-10-19 09:32 AM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
06-10-19 09:25 AM - Post#2768121
Cheaper welders like that tend to have an unstable arc, which makes it more difficult to get a nice weld bead with one. The cheaper welders use a lighter transformer which can't maintain as steady an arc voltage.
Ray P W
Reg: 09-30-15
06-10-19 12:30 PM - Post#2768148
In response to 65_Impala
"I have been looking at the ones at harbor freight. Does anyone have any experience with these welders"
Airlifter,
A friend and former workmate of mine (we're geologists) had a HF mig machine fail in occasional hobby use. It was outside of the warranty time limit but he took it back to them, anyway. Instead of repairing it they replaced it with a new unit at no cost.
So it's a good news/bad news answer. They replaced it at no cost totally satisfying my friend. But, he's a really experienced welder and didn't abuse it so it should not have failed.
My experience with electric welding is I had a 240 volt 180 amp Absco buzz box that worked perfectly for about 40 years. Then I gave it to my son and now he's using it now with no issues.
My "New" welder is a Miller AC-DC stick/tig "Synchrowave 200" that is now about 12 years old. I really like the AC-DC versatility because I can tig aluminum and ferrous metals.
Looking back at all the welders I've seen in hobby use the only one that ever failed was my friend's from HF. My take away from that is that a quality welder will outlast its owner in hobby use.
I've never regretted buying quality tools. My oxy-acetylene welding rig is a genuine Victor (not Victor "style") bought in 1969 and except for replacing each of the regulator diaphragms once it's been totally trouble free for 50 years. Finding someone willing to sell me the diaphragms was a challenge, though.
Ray W
65_Impala
Reg: 12-29-02
06-10-19 12:52 PM - Post#2768149
In response to Ray P W
Ray - I made a set using an inner tube. They worked just fine.
Site Ambassador
06-10-19 06:39 PM - Post#2768184
Check Craigslist and such. People do sell good welders used when they either finish a project or buy an upgraded welder.
1957 Cameo Carrier |
Ray P W
Reg: 09-30-15
06-10-19 08:11 PM - Post#2768188
In response to wagonman100
"Ray - I made a set using an inner tube. They worked just fine"
That's a great solution Impala. How long have those been in service?
65_Impala
Reg: 12-29-02
06-11-19 05:33 PM - Post#2768265
I don't know. Did it years ago but haven't used them in a while. If the rubber fails I'll just do it again.
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
06-12-19 03:44 PM - Post#2768342
I bought my Miller 180 Autoset 10 years ago and have never had a problem with it. I recently bought a Miller Diversion 180 tig welder. I justified the money spent on reliability and local availability of parts and accessories.
Maxbigblock
Site Ambassador -
Loc: Stuart, Florida
Reg: 12-16-01
06-18-19 04:25 AM - Post#2768733
In response to tommy49
I have been welding most of my life. A good quality welder new or used is a long term investment. Its one of those things that you are better getting something that is a little more than you had planned on spending. If you take care of your stuff, quality tools pay for themselves and cheap tools just cost you money. There is nothing worse than being in the middle of a job and your equipment either dies on you are just isn't up to the job that needs to be done.
Max
I'm originally from the ONCE great city of Flint, Michigan. The birthplace of General Motors, where A C Spark Plug was formed and headquartered, where the first Corvettes were hand built, and where my 1955 Chevy was made.
Edited by Maxbigblock on 06-18-19 04:32 AM. Reason for edit: No reason given.
KShortell
Member #1510 Senior Member
Loc: Chesapeake, VA, U.S.A.
Reg: 04-14-01
06-18-19 05:56 AM - Post#2768743
One other option is to keep an eye out for private label rebranding of one of the major players' offerings. For example, my Hobart Handler 140 is labeled as a "Weldmark 140 by Hobart Brothers" with the "Hobart Brothers" in small print. Weldmark is a regional welding distributor. Basically, it's a full on Hobart Handler 140 with a sticker package. However, it also allowed me to buy it at a great price because most folks didn't realize what it really was.
While I can run MIG or Flux Core in my unit, I've just been running flux core as I've mostly been doing outside work on fences, trailers, etc. I did weld a bit on my wife's Jeep, though. A bit tricky on sheet metal, but I wasn't welding exterior body panels. Someday, I'll finally get around to obtaining a MIG bottle.
While many folks often recommend a unit larger than you think you need, it is important to be honest with yourself as to what you intend to achieve with a particular unit. Sometimes, we progress on to bigger and bolder projects. Other times, we just have grandiose dreams about building the next supercarrier in our garage. Buy what you'll really need and buy quality. You won't regret that at all.
For example, my '08 Silverado is an LS model, not a W/T or an LT. I love it-- everything I need and nothing I don't.
Good luck!
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
11-08-19 05:48 AM - Post#2779767
In response to Stephen009
I bought one of the little wire welders from Harbor Freight, was on sale for $99, thought it would be good enough for a small project I had. 24 spools of wire later, its still ticking, and runs on the end of a 100" extension cord.
They asked me, why a Four door, and a Six, and I told them, JUST BECAUSE. |
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
04-02-20 10:42 AM - Post#2790114
In response to KennyQman44
Years ago I purchased a MiG welder at a swap meet, it was a brand I had never heard of before. It worked ok, but I was not happy. I later bought a Miller MiG welder and sold the other one and have never looked back. I am very happy with my Miller.
'96 Replica of a 1950's Teardrop Trailer. |
johncore
Reg: 09-20-20
09-28-20 01:30 AM - Post#2804404
chevkarl
Reg: 10-01-13
01-07-21 12:24 AM - Post#2811555
I would try to find a used Miller or Lincoln.
mathewjaxon
Reg: 03-22-21
03-23-21 03:28 AM - Post#2816654
I'd suggest going for Miller Welders. Particularly for MIG welding, the Miller Millermatic 211 is the best choice.
It is a competitive MIG WELDER along with the auto-set feature that allows you to weld with little to no professional help.
Check out the comparison of Millermatic 211 with like 11 other heavy-duty welders by Hobart, Forney, Lincoln, Lotos welders here.
https://weldingrage.com/best-mig-welders/
04-17-21 09:09 AM - Post#2818215
my little firepower welder from napa recently died. it was a decent machine that lasted longer than i thought it would. almost bought another one that was on sale at a very good price but i opted for a 210 hobart for under 1k. i got the hobart cause it has 7 heat settings and less electronics. and the price was right.
