Username Post: Steering lockup 2001 Silverado 2wh        (Topic#356687)
chnaus
Loc: Upstate:The Real New York
Reg: 04-18-03
06-04-19 06:25 PM - Post#2767716
Pulled in ,shifted into reverse tried to turn the
wheel. I pulled as hard as I could, the steering
wheel turned very little one way only. Luckily
in the direction I was backing.
When I looked under the truck fluid had run out of
both ends of the rack and was dripping good from
the back of the power steering pump. It was empty.
All I could say was "What the hell".
Has this happened to anyone else
What might be the fix
CH
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-04-19 07:07 PM - Post#2767723
    In response to chnaus
So wait it had fluid coming out of the rack and the pump...
Put the front end up and see if the wheels turn back and forth freely.
Check those balljoints. You may have seized joints.
Is the rack original or aftermarket?
Old School GM fan FOREVER
Execution time: 0.093 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:38 AM
