Username Post: Newbie 1947 Fleetline 4 Door        (Topic#356667)
P.schmidt90
Reg: 06-03-19
06-03-19 04:53 PM - Post#2767638
Hi! I have recently been gifted my family 1947 Fleetline 4 door sedan. It is completely original. Engine and transmission have never been touched. The body was rattle canned forest green 20 years ago but was originally lullwater green I think. This car runs and drives well. I want to completely restore the vehicle but I am looking for where to even begin. My mind goes to completely replacing the drive train, engine, suspension, etc but I am not sure where to start.. I am hoping someone can at least point me in right direction. Thank you!
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
06-03-19 09:00 PM - Post#2767652
    In response to P.schmidt90
Congrats on your getting your Chevy. The very first thing you want to do is decide on what you want as a finished project. Do you want to restore it to factory original? Rebuilding the original suspension, drivetrain, original upholstery and paint? Or do you want to build a street rod with a V8, automatic transmission, creature comforts such as A/C, late model rear end, aftermarket suspension, custom paint and interior? Having a plan and a vision are very important. Nothing slows or stops a project like changing course during the build. Good luck and welcome to one of the most rewarding and and at times frustrating hobbies around.
06-04-19 12:56 PM - Post#2767693
Welcome to ChevyTalk. Both of my old Chevys are stock. I don't drive them as much as I should, but that is the way it is.
Good luck with what you decide.
29-41, 42-48, 49-54 Moderator
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
06-04-19 02:36 PM - Post#2767700
They're only original 1 time...
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2017 Silverado LTZ 6.2
2020 Blazer Premier
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
06-05-19 07:19 AM - Post#2767744
Do not touch a bolt until you have decided what you want out of the car, once having done that you can then see if it will be affordable to do what you want. Next step is to plan where, when what and how. With all that done you should be able to stick with it til it is done and then enjoy what you have created.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
06-05-19 11:50 AM - Post#2767760
    In response to 2blu52
I fully agree ! One thing to remember,it's going to be very expensive either way.
Edited by pauldian on 06-05-19 11:51 AM. Reason for edit: No reason given.
P.schmidt90
Reg: 06-03-19
06-05-19 12:31 PM - Post#2767765
    In response to lofat46
Right now I want to stay original. My fear is finding parts to rebuild the vehicle. Are there sites that have everything I need?
P.schmidt90
Reg: 06-03-19
06-05-19 12:33 PM - Post#2767766
    In response to pauldian
I'm planning to stay as original as I can. I'm not sure if there are even parts out there. Can someone point me to the right place for someones previous restoration? My fear is that if I stay completely the engine or transmission will die and I will need to replace them anyways when it should have been done in the first place.
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
06-05-19 04:07 PM - Post#2767784
As Blu said What do you want out of your car? Access your drive train. Drive it around some and see what you think on performance an soundness. The original drivetrain is not real friendly to todays Highway speeds. 216 3 speed 411 rear. Just Fine as a parade car or local ride. Four lane cruiser not so much. You can add overdrive and gear it up and still look completely stock with 216. You can upgrade to 235 full pressure oiling and gain some power and still look stock many possibilities. Keep reading you are in the right place to figure out what you want out of your new ride. It all doesn't have to happen at once Good luck. And Happy Motoring
Tom
48 sports coupe
63 C-10 long fleet
17 Tacoma double cab longbed
19 Toyota Rav-4
Been down most all the roads nowhere left to go??
P.schmidt90
Reg: 06-03-19
06-06-19 01:34 PM - Post#2767842
    In response to RoadRocker
What are the preferred newer engines to install? Can you get something that will bolt to the original mounts? Are there kits for different engine mounts if not?
What about rear axle/differentials? What are the preferred replacements for these?
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
06-07-19 05:57 AM - Post#2767876
All inline sixes from 1937/ 1962 pretty much bolt right in. later 235 after 55 are good because of full pressure oiling. 261 are popular. Blazer 4x4 5 speed trans and rear are common and work well, open driveline. Auto trans also used. All depends on what you want out of your ride
48 sports coupe
63 C-10 long fleet
19 Toyota Rav-4
P.schmidt90
Reg: 06-03-19
06-07-19 07:20 AM - Post#2767879
I want to keep this as a parade car, maybe a weekend driver for the fun of it. I do not plan on turning it into any type of street rod.
Thanks for the engine advice. I'll be relocation to Phoenix in a month. Once the vehicle gets down there I guess its time to see what parts I should start order.
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
06-07-19 08:01 AM - Post#2767882
Again good luck with it. Original 216 3 speed will work fine for your intended use.
Tom
48 sports coupe
63 C-10 long fleet
19 Toyota Rav-4
P.schmidt90
Reg: 06-03-19
06-07-19 08:00 PM - Post#2767932
Tom- should I just buy a rebuild kit for the engine?
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
06-08-19 05:37 AM - Post#2767941
As said drive it around if you can and see how it is. Does it use oil? Do a compression check. Fix what wrong. Oil leaks? Does it run hot? My 216 in 48 coupe was all good Yours could be to. I switched to 261 for better roadabilty and am really glad I did. Different strokes
Tom
48 sports coupe
63 C-10 long fleet
19 Toyota Rav-4
06-08-19 07:26 PM - Post#2767993
Took my 48 for a 25 mile drive today and going to take it to a small car show in the morning. One of the first things to look for is a Powerglide rearend and just change out the torque tube assy. This will change your 4.11 rear ration to a 3.50. Slows the engine RPM down so it will last longer. Then maybe keep your eyes out for a full pressure 235 or 261. This way there is hardly any fabricaton needed.
P.schmidt90
Reg: 06-03-19
06-12-19 10:47 AM - Post#2768317
Thanks for the Advice! I'll defiantly be on the look out for the engines. Any ideas on where to find the new rear end?
Execution time: 0.096 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:37 PM
