Username Post: Heater shutoff valve        (Topic#356635)
Whitetail Hunter
"2nd Year" Platinum Supporting Member
Whitetail Hunter
Loc: Green Bay Wisconsin
Reg: 03-28-15
06-02-19 06:11 AM - Post#2767531
Did a 66 with a/c use a heater hose shutoff valve? I cant find any pictures showing one.
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
06-02-19 03:08 PM - Post#2767555
    In response to Whitetail Hunter
The comfortron models had what looked like a shut-off valve on the passengers side inner fender. This wasn't a shut-off valve, but just a temperature operated vacuum switch. These were sometimes incorrectly called a heater valve.
Steve
1966 Caprice 396 496 496mkII TH400
A White Sport Coupe
A White Sport Coupe
Reg: 08-19-10
06-02-19 03:22 PM - Post#2767561
Hi Whitetail
Quoting from the service manual
"Since the unit has no water valve, circulation keeps the core hot at all times. Air passing through the core receives maximum heat from the core."
The four season system and the Comfortron system.
"The temperature knob through its Bowden cable, actuates the door which controls outlet temperature. Since the heater core in this system is hot at all times, this door shuts off the heat when not wanted as well as mixing the hot and cold air.
Comfortron system
The thermal vacuum valve has no control over the circulation of hot water.
The dealer installed custom system runs entirely independent of the heater.
Bob
Whitetail Hunter
Whitetail Hunter
Reg: 03-28-15
06-02-19 04:27 PM - Post#2767567
    In response to A White Sport Coupe
Looking at the heater box and that door. I thought the valve was not needed. But i had one from all the parts I have collected. Thanks for the confirmation.
Execution time: 0.132 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:52 PM
