 Page 2 of 2 <12
Username Post: 3 wire alternator and then engine problem        (Topic#356611)
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
06-17-19 04:49 AM - Post#2768631
Yes I meant before. And no. That’s what’s weird. It’s running it’s best. I’ve tuned with a vacuum gauge a million times. This motor and others. Always went for greatest, steadiest vacuum and got the best idle as a result but this is different
After a 15 mile drive last night, got home and it was running fine. No more stumbling up the driveway. Wonder if it was the vacuum leak? Or the 35 year old alternator? Both were fixed over the weekend. I put in a new one wire (old one was under warranty!!!!)
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Edited by drew1987 on 06-17-19 04:50 AM. Reason for edit: No reason given.
06-17-19 06:02 AM - Post#2768639
    In response to drew1987
Great, maybe some fouled plugs,and/or low ignition voltage causing fouling? Always nice to know the resolution.
drew1987
drew1987
Reg: 02-23-14
06-17-19 08:06 AM - Post#2768664
Well, this is a classic case of fixing too many things before checking if it worked
I cleaned the spark plugs and re-gap them, That didn’t solve the problem.
I fixed the intake manifold gasket leak, and also got rid of the 35-year-old incorrect alternator, now it seems better, so I’m not sure which of the two it was
Member:
Edited by drew1987 on 06-17-19 08:06 AM. Reason for edit: No reason given.
drew1987
drew1987
Reg: 02-23-14
07-24-19 09:01 AM - Post#2771445
Meant to report back here sooner. This has never really gone away. The longer I am out and about, the worse the idle gets... usually not enough to be that noticeable but last night i ditched my local club ice cream social cause it was 25 miles away and I didn't want to break down. Irritated becuase I cant find out what it is. Its not the control module or coil, plugs, or wires (no arcing so assume the 3,000 mile wires are good)
I did the intake manifold gasket, the carb base gasket, increased the fuel pressure (installed regulator last year - figured that could be it)....
The other day it was real bad. I drove about 4 miles, purchased something, and drove home (i did light up the tires pulling out - oops) and when i got in the driveway, it was idling lumpy like a cam, like it was going to stall. A little throttle and it just about dies then springs to life and revs, jerking the car forward....
I almost wonder if I should bypass that fuel pressure regulator? I installed that trying to reduce the gas smell, thinking it was running rich as gas was being forced by the needle/seats... anything else would be helpful.
Member:
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
07-25-19 12:20 AM - Post#2771504
Drew, Did you remember to disconnect the vacuum advance when you timed it?
Also, are you using ported vacuum up on the carburator or are you using manifold vacuume fot the timing?
Just Slightly Abrasive
50hotrod
50hotrod
Reg: 07-25-11
07-25-19 06:03 AM - Post#2771514
    In response to 40grit
Drew,
Just a thought I have.
You have always (to my knowledge) driven your car nicely in the past. From your posts, it seems you are getting a little more aggressive with your "hotrod". Not a bad thing, just an observation.
What might be happening is you have some dirt or sediment sitting in the bottom of the carburetor float bowel. When driving aggressively, it might be getting agitated enough to cause it to get into the jets....causing the erratic running condition coming and going.
This is just a guess. I have experienced this in a similar situation.
How I diagnosed it was to choke off the air flow to the carb, while running, by putting my hand over the top of the air horn. This would force the carb to draw gas hard thru the jets....clearing the fine debris and it would then run good for a while after that.
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
drew1987
drew1987
Reg: 02-23-14
07-26-19 02:38 AM - Post#2771619
    In response to 50hotrod
I will try that!
Over the years I’ve gotten on it here and there - it almost begs me to. It’s the most powerful car I’ve ever had. If I remember the night this started, I took a left onto a wide, straight road with no traffic and just stayed in the throttle. Won’t tell you how fast I was going when I looked down. But I drove for an hour after that with no issue. But when I got home...
I think it was before all this that I tamed the timing a
But. Better idle albeit less vacuum. I wondered about heat. I have a 185°f thermostat. Was going to try a 160
Now you’ve got my wheels turning. When the symptoms start, it smells like this weird smell it made the time I ran out of gas (two times in my life, both in this car and there is NOTHING wrong with the gas gauge). Almost like a kerosene heater
Member:
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
07-26-19 04:50 AM - Post#2771624
Last fall & this spring, I was plagued with a bad running motor and was convinced it WASN'T a carb issue. I did valve adjustments several times, new coil, removed the Pertronix, new points condenser, everything, I couldn't accept the fact it could be the carb that I meticulously rebuilt. Out of options, I built a carb out of three junk carbs, and the engine ran fine. Never take anything of granted.
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
drew1987
drew1987
Reg: 02-23-14
07-27-19 04:54 AM - Post#2771706
    In response to tommy49
I am thinking that may be it. I am going to order a rebuild kit and go through it. Change the fuel filter while I’m at it
Member:
drew1987
drew1987
Reg: 02-23-14
07-27-19 04:55 AM - Post#2771707
After I do a 160° thermostat
Member:
drew1987
drew1987
Reg: 02-23-14
08-20-19 10:14 AM - Post#2773673
Hey sorry I dropped the ball here i must not be subscribed. Yes i meant before, and its down to this:
It literally idles perfect when it starts. It gets worse at it warms up, but not too bad... just off of idle is terrible... if I increase from idle by 100 RPMs or so, the motor shakes and sort of stumbles, but at a constant, as long as I hold the RPMs there... once I get to about 1,000 RPMs, everything is fine. Its driving me crazy
Member:
drew1987
drew1987
Reg: 02-23-14
08-30-19 07:19 PM - Post#2774526
Yup.
Attachment: 2C241586-480E-4B74-9638-4A960F5EEDE2.jpeg (2.32 MB) 3 View(s)
Attachment: D1027762-EFDD-42DD-A89C-83D4006B4083.jpeg (1.03 MB) 2 View(s)
Member:
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
08-31-19 06:26 AM - Post#2774551
So I assume it just quit and left you stranded?
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
drew1987
drew1987
Reg: 02-23-14
09-01-19 05:37 AM - Post#2774611
    In response to one4dad
Yea. Only the second time in 5 years 11,000 miles. Not bad for a 70 year old car I guess. One other time but it was physical damage and I got back on the road.
I puts for 20 minutes but ended up seeing my carb dropping from the front two jets down the tubs, AND out the side. Tells me some shmutz made it past the fuel filter and clogged something (needle and seat?) open perhaps. At this point, I’m in professional clothing without the tools for opening the carb even if I wanted to
Member:
tommy49
tommy49
Reg: 09-28-12
09-01-19 06:24 AM - Post#2774614
"Professional clothing"? You mean a suit, because this also professional clothing.
Attachment: work_shirt.JPG (177.85 KB) 1 View(s)
Tommy
drew1987
drew1987
Reg: 02-23-14
09-01-19 07:59 PM - Post#2774647
Tommy im kakis and a dress shirt. I have a tie collection I never want to wear again. Suits are for special occasions. I work on cars in light colored clothes no longer fit for daily use and I don’t spend money on any of it ;-)
Member:
drew1987
drew1987
Reg: 02-23-14
09-01-19 08:02 PM - Post#2774648
By the way- as irritating as the whole experience is, even on tow truck, i love the lines of that car. It’s a keeper
Member:
tommy49
tommy49
Reg: 09-28-12
09-02-19 05:43 AM - Post#2774659
I was commenting to the phrase "professional clothing". The term "professional" seems to identify those that wear "dress clothing" and work in an office-type environment. I consider myself a professional and was displaying my professional attire. As for my workwear in the shop, GM shirts and cargo pants. I don't own any jeans.
I feel your pain on coming home on the "hook". Been there. On the way to a bicycle tour, we ran over a beauty ring on the freeway with a van, punched a hole in the tank. Pulled into a gas station and ask for speedy dry and a container. Because of the leaking gas, they called 911. Two fire trucks and the Sheriff showed up, along with the gawkers! You'd think the gas station was on fire! What a circus! In the end, it was a long miserable 60 mile ride in an old, ratty tow truck.
Tommy
drew1987
drew1987
Reg: 02-23-14
09-02-19 07:08 PM - Post#2774708
Yikes man! What were you in?!
Professional to me means an expert in his or her field. Not white collar bias. Shoot I wish I can go back to high school graduation day and tell my self “TRADE!!!!” My gift is hands on and I know how to run a business. I wish I was a master electrician or something.
Member:
tommy49
tommy49
Reg: 09-28-12
09-04-19 05:14 AM - Post#2774794
Referring to?
Tommy
drew1987
drew1987
Reg: 02-23-14
09-04-19 06:37 PM - Post#2774840
when your gas tank ruptured
Member:
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
09-04-19 07:30 PM - Post#2774848
Drew,he said he was in a van.
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
drew1987
drew1987
Reg: 02-23-14
09-05-19 05:03 AM - Post#2774858
    In response to Lead sled
Good call. Missed that
Member:
drew1987
drew1987
Reg: 02-23-14
09-08-19 03:05 PM - Post#2775060
Ok. I think the issue is solved. Rebuilt the carb. I did find a crack in tip of the end of the longer/larger rounded-end tube in the secondary Venturi on the left side. Came that way cause I’ve never been into it. Irritating because I also found an EXTRA accelerator pump spring in the left bowl, holding the float open, RIGHT OUT OF THE BOX in 2016 when I built the car. I’m calling Edelbrock and asking for a free replacement part because it would appear my carb was made on a day no body cared about their work.
Now the car doesn’t stumble. Seems to run better than it has in a while. I still think I have a vacuum leak. Working on building a smoke machine to try to find it.
I noticed my alternator gauge shows 12 volts at idle and then instantly goes to 14 off idle. I can’t imagine this is correct?
Member:
drew1987
drew1987
Reg: 02-23-14
09-13-19 07:22 PM - Post#2775486
Cars gone 200 miles since. Runs as good as before the drama
Member:
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
09-13-19 07:41 PM - Post#2775488
Nice work Drew! I love stories with happy endings!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
drew1987
drew1987
Reg: 02-23-14
09-14-19 05:21 AM - Post#2775496
    In response to mahlmann
Getting there!! Still idles like crap. If I can’t find a vacuum leak then I guess it’s the motor. All cylinders make between 101 and 119 psi but with they much of a variation that could be it
Member:
drew1987
drew1987
Reg: 02-23-14
09-15-19 07:15 PM - Post#2775611
  • drew1987 Said:
Interesting findings:
The motor makes between 111 and 120 PSI on all cylinders so thats fine, I did find a vacuum leak where the intake manifold meets the block on bank two, in the middle. I'll have to deal with that.
Reflecting on this, is 111 to 120 ok and is such a swing between cylinders acceptable? I am wondering if this is why it’s not smooth at idle not matter what I do. Can’t complain if the motor isn’t perfect cause it was virtually free and has kept me going. I’d like to try, though.
Member:
 Page 2 of 2 <12
Execution time: 0.113 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:23 AM
