Username Post: 1954 Belair 4 door        (Topic#356592)
Shaff54
Loc: Janesville wi
Reg: 09-27-15
05-29-19 06:57 PM - Post#2767299
Selling my project car. Had body off frame and on a rotisserie where the tub was blasted inside and out then epoxy coated. Underside and inside floor pans of car have bedliner applied. Frame was also blasted and coated an industrial coating. Pre bent stainless steel break lines are mounted to frame but not connected. Bought stainless steel full body bolt kit. New brake drums and e-brake cables. Has a 235 from I believe a 1961 truck. Engine ran when pulled but head has been pulled. If someone is looking to build a good solid car this is it. Blank slate. Looking to get 3500.
Attachment: AACC9F9A-B283-481D-A04C-41B4DCC8251D.jpeg (378.68 KB) 9 View(s)
Attachment: 87D91D3D-D170-46D3-A0F4-597C7EBC2806.jpeg (275.97 KB) 8 View(s)
Attachment: 871E9759-F0F2-4679-AF19-5207AC3B8634.jpeg (408.86 KB) 8 View(s)
Edited by Shaff54 on 05-29-19 07:13 PM. Reason for edit: No reason given.
Execution time: 0.099 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:02 PM
