Username Post: LT-1 distributor        (Topic#356570)
corvesy
corvesy
Reg: 08-07-08
05-27-19 05:44 AM - Post#2767167
What are you guys doing for a reliable LT-1 distributor these days? I am on my second one from the parts store.
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-27-19 01:50 PM - Post#2767200
    In response to corvesy
AH YES,THE OPTI SPARK.
I HAVENT HAD THE JOY TO R&R MINE YET.
BUT UPON READING JUST ABOUT EVERYTHING.
THIS PLACE IS RECOMMENDED.
https://www.saccitycorvette.com/AIPOptiSpark.html
I ALSO RECOMMEND MY ONLINE MENTOR INFO
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Mel Foye
Mel Foye
Reg: 09-29-00
05-29-19 09:29 AM - Post#2767287
Also check out Eckler's.
Member #409
07-05-19 03:28 PM - Post#2770007
    In response to Mel Foye
Been a while, but a few years back the "go to" deal was a new one from a Chevy dealer.
Also, if you have a 92-94 model, consider doing what it takes to go with a "vented" opti unit, which came on 95-97 models. Takes a couple of mods to install, but the vent setup evacuates the corrosive gases inside cap/rotor area and increases life.
The auto supply ones have a reputation for being junk.
The other thing to consider if you're changing the opti is to change the water pump too. Cause if you don't and it leaks out the weep hole or the shaft drive seal - it takes out your new opti.
Execution time: 0.093 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:39 AM
