Username Post: equinox A/C        (Topic#356546)
REBORN55
Loc: DeSoto, Illinois. 62924
Reg: 01-21-01
05-24-19 12:06 PM - Post#2767023
have a 2012 equinox--4 cyl. A/c is starting to blow warm--first start up this morning backing out of garage was nice and cool---further we drove it got less effecient---to the point of it barely getting cool---87 degrees out and it is blowing 70 out the vents on high--pressures are 30 on low side---250 high side. need a little guidance---as to the possibilities of expansion valve having dirt in it or blend door not working righ as with other GM products--thanks
Ken http://www.picturetrail.com/reborn55
05-25-19 05:21 AM - Post#2767057
    In response to REBORN55
Do the low side pipes under the hood feel cold to the touch when this happens?
REBORN55
Reg: 01-21-01
05-25-19 06:25 AM - Post#2767062
I don't remember will double check---was working fine last night
05-26-19 05:03 PM - Post#2767140
Are the cooling fans turning on?
REBORN55
Reg: 01-21-01
05-26-19 05:56 PM - Post#2767145
Yes
05-27-19 04:42 AM - Post#2767160
At 85 degrees, low side pressure should be 45+ PSI or so. ~225-250 on the high side. Is the compressor a variable pressure type? I think most modern compressors are variable pressure now. Sorry, I don't have enough knowledge on how those work. Newer systems do set codes for scanners to read.
Definitely check blend door movement.
Execution time: 0.183 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:15 AM
