Username Post: LS swap in 72 C10?        (Topic#356545)
doubleE
Loc: Eagan MN
Reg: 06-02-03
05-24-19 11:41 AM - Post#2767022
Having thoughts of doing an LS engine swap. The 307 is healthy but thirsty. I have replaced the 3-on-the-tree with a 700R4 which helped push the MPG to 15 to 18 highway if I’m really easy on it and a good tail wind. She has a 3.72 rear. I’ve heard some good things about the LS engine family and wonder if I should pursue this. Have 0 experience with the LS and would like to hear some input from anyone that has some. Like what years, size ect. I see there are kits out there for the 67 – 72 C10s. Would like to keep the 700R4 or would I need to go with a electronic OD tranny? My objective would be higher MPG and improved drive ability, not high performance/power.
Eric
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-27-19 05:16 PM - Post#2767207
    In response to doubleE
I WOULD LOOK INTO THE FUEL REQUIREMENTS OF THE LS YA WANT 2 USE.
EXAMPLE MY DAILYS USE REG AVG $2.80
MY LT-1 PREMIUM AVG $3.40
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
mcdarrunt
Reg: 11-07-18
11-02-19 02:06 AM - Post#2779345
    In response to TAT_2
We have done several LS swaps into 69-72 C10's and it is a very straight forward procedure. Even the lower radiator hose to engine fits due to the factory cross flow radiator. Both exhaust manifolds let the pipes clear the frame and steering shaft has clearance. The ones we did had the 4l60E or 4L80E overdrive trans so can't enlightened you on using a 700R4. The LS engines have a reputation for good power, great fuel economy, and a 250k-300k lifespan. Pic is of a 70 with Vintage heat/cool so former plenum space can be used for computer components.
kwhizz
kwhizz
Reg: 01-01-07
01-12-20 05:23 AM - Post#2784226
    In response to mcdarrunt
Holley / Hooker makes a kit for mounting the engine/ Trans assy right in....... I would stay with the computer controlled trans as GM intended.....
impalex
impalex
Loc: Long Beach, CA, USA
Reg: 03-13-05
01-14-20 09:57 AM - Post#2784379
Hi mcdarrunt,
Sounds like you've done enough of these to have a system in place for making it easy. By any chance have you posted any threads where the process is laid out? Or can you link me to a thread where it is laid out?
Also, do you know what kind of mileage you're seeing once the LS Swap is in place?
I really love my completely original 350 and drivetrain (the Quadrajet carb 255hp version). I even love the 4 spd Muncie Trans. Damn it is a joy to drive. The 10mpg though, that's hard to swallow. It leaves me open to considering the LS Swap as an option.
I look forward to hearing your thoughts, or anyone else's thoughts if someone else has anything to share.
65 Impala SS w/327 and TH350 trans. "Ignorance is the parent of fear" Herman Melville-Moby Dick When it comes to cars, the above is very true!
Execution time: 0.222 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:30 PM
