Username Post: Carb adapter advice        (Topic#356528)
Arti
Reg: 10-09-18
05-22-19 09:20 AM - Post#2766932
Hi guys
Got a 3837109 intake on it's way and an Edelbrock 500 sat on the shelf, both of which are going on my 265. I just need to know which adapter to order to mate them together. There seems to be several and wanted to order the best one.
Any recommendations? Thanks in advance.
carbking
carbking
Loc: Missouri
Reg: 06-14-03
05-24-19 07:04 PM - Post#2767045
    In response to Arti
Recommendation:
If you are going to use the clone, get a cheap aftermarket intake that has the correct base footprint for the clone.
Any adapter used with the clone will perform WORSE than the original carb.
Give the clone a chance by using a manifold which matches the clone.
Jon.
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes!
557B2100
557B2100
Reg: 06-02-13
05-27-19 07:11 PM - Post#2767212
    In response to carbking
Arti.....You need an adapter that will go from a small square bore manifold to a larger square bore carburetor....Here is a link: https://www.ebay.com/itm/261529255525
Execution time: 0.125 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:17 AM
