Username Post: 66, 327 wont start after a trip of 20 miles or so        (Topic#356500)
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-20-19 09:48 AM - Post#2766799
I am running a 66, 327 engine in my 52 Chevy Coupe! Runs strong, but after a 20 mile trip or so , temperature at about 180 heat when I turn the engine off, it won't won't restart till it sits for a half hour or so! I have re-routed the fuel line and insulated it thinking I was creating vapor lock!I have adjusted the carb and timing to no avail!! Anybody have any suggestions?
1975 Corvette, Original owner
1953 Chevy 3100 Pickup
1952 Chevy Styleline Coupe
http://sites.google.com/site/bluejaygarage/
6T5
"2nd Year Gold Supporting Member
6T5
Loc: Asheville, NC
Reg: 07-22-17
05-20-19 10:30 AM - Post#2766807
    In response to coachfrank
Could be a few things but first what carburetor and intake manifold do you have.
...Ed
1965 Impala SS
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-20-19 10:57 AM - Post#2766809
    In response to 6T5
Edelbrock 650, and a performer RPM manifold
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-20-19 11:40 AM - Post#2766811
Does it 'slow crank'?
Crank properly but just won't start?
I had a 'slow crank' problem that would show itself after the car was run for about 1/2 hour; 'cold' everything was fine. It improved with retarding the timing a little but did not go away until I replaced the negative battery cable.
Just a possibility.
Pete
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
05-20-19 11:59 AM - Post#2766812
Could be related to the carb experiencing high temps in which case a bakelite spacer would help
It worked for me on my 69 mustang with aluminum intake and Holley carb
Easier hot starts once the edelbrock 1” aluminum spacer was replaced with a genuine 428CJ bakelite spacer measuring just over 1/4” thick
Ryan
Build date Dec. 21 '64 Oshawa
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-20-19 03:01 PM - Post#2766816
    In response to Oshawa65SS
No on the slow crank, cranking sounds fine!Tried a bakelite spacer! Still doing the same thing!!I am at my wits end! Even thinking my heavy OTB air cleaner may be holding heat in!
chopr1
chopr1
Reg: 01-11-19
05-20-19 07:41 PM - Post#2766829
Just a old mans 2 cents. If you got fuel & spark it should fire (right). May squirt a shot of fuel in the carb. that will take care of the fuel. If it doesn't fire, could be electrical getting hot some where. Just throwing some things out. Been there on these frustrating little glitches, and it usually turns out to be something minute! Good luck!
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-20-19 08:03 PM - Post#2766830
    In response to chopr1
Thanks Chopr1 ! Yep, been there before, I know I will eventually find the problem, just gets a little frustrating sometimes!!
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
05-20-19 08:50 PM - Post#2766831
Had the same problem on one of my cars, did everything to no avail. Mine was vapor locking the same as I think yours might be doing. E-10 gas has a much lower boiling point than leaded gas. Anyway I installed a electric fuel pump and haven't had any trouble for the past 4 years. Might be the problem might not ?
brasii
Loc: FRANCE
Reg: 11-09-07
05-21-19 05:32 AM - Post#2766834
Have you HEI ? I 'd the same problem : when engine hot , problem to restart ..and 20 min. after , no problem : it was the HEI module
impala 66 convertible
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-21-19 06:13 AM - Post#2766837
    In response to brasii
Yep, I have an HEI, Thought about pulling it. My son suggested going EFI with the Holley Sniper Kit! Might try the electric fuel pump! Thanks everybody for your suggestions!
Edited by coachfrank on 05-21-19 06:35 AM. Reason for edit: No reason given.
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
05-21-19 09:10 AM - Post#2766848
Just as coachfrank mentioned I also had a module go bad. Replaced and all was good. One other thing have you looked down the carb after cutting off to verify there's no fuel dripping down? Just throwing some ideas out. Be sure to let us know what fixes it...
...Ed
1965 Impala SS
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
05-21-19 11:15 AM - Post#2766855
Could also be a short in the HEI coil that doesn't act up until it gets hot.
Johnny
1965 Impala SS
505/4-speed/3.90
kwhizz
kwhizz
Reg: 01-01-07
05-21-19 01:28 PM - Post#2766866
    In response to Johnny468
Did you bypass the resistor wire???
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-21-19 01:47 PM - Post#2766870
    In response to kwhizz
Not yet, that's what I was going to try next!!
66SS632
66SS632
Loc: Langley BC
Reg: 02-09-13
05-21-19 01:53 PM - Post#2766871
Is it an aftermarket HEI unit or stock GM?
Aftermarket Chinese made knock offs are CRAP !! They always fail. Electronics are garbage and the shafts are always problematic.
Engine shops that get crate engines with cheap distributors rip them out first thing.
As has been suggested the module is likely your problem.
Get a good one.
Also make sure getting 12 volts sourced from ignitionand not resistor wire.
Still a 17 year old delinquent Hot Rodder
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-21-19 06:16 PM - Post#2766893
    In response to 66SS632
Pulled the module, 4 prong, tonight, will get a new one tomorrow
brasii
Loc: FRANCE
Reg: 11-09-07
05-22-19 05:45 AM - Post#2766916
and obviously good layer of grease under the module : it doesn't like warm..
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-22-19 06:10 AM - Post#2766918
Yes, there was a good layer of grease under it! Do I need to grease it or not? My first time getting inside an HEI!
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-22-19 10:15 AM - Post#2766937
Make sure you use heatsink/dielectric grease
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-22-19 10:55 AM - Post#2766941
    In response to aghaga
Yes on the grease, just picked the part up! Will install later today!!
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-22-19 03:19 PM - Post#2766956
Ok, First test run with the new module went great! Got the temperature up to 180 degrees, outside temperature 83 plus high humidity! Let it run in the garage for another 15 minutes and shut her off. Started on the first turn! Went down 10 minutes later and she started! So far so good! Will give her a much longer run tomorrow if the rain holds off! Thanks to all for your support!! Coach Frank
chopr1
chopr1
Reg: 01-11-19
05-23-19 12:29 PM - Post#2766985
Hope this cures it! Now, which HEI is a good replacement for the distributor. I still have the distributor in my 65. Again, I'm am the older generation so am not up on the new stuff. I see them (complete unit) from $100.00 to 400.00. Which one have you guys chosen as a good one. I'm a old 'points' man, but would like to update this part.
rick1965
Loc: joliet ill
Reg: 12-07-16
05-24-19 05:39 AM - Post#2767008
im an old points guy too, but for 90 bucks i decided to try a pertronix breakerless set up for my 65. so far so good. rock solid dwell/timing,and you use the distributor you already have. have heard a couple of horror stories about the magnetic ring, but with proper spacing, shouldnt be a problem. keeping an eye on it from time to time.
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
05-24-19 07:28 AM - Post#2767011
    In response to rick1965
I used the pertronix system in our 72 Nova for 5 years and never had any problems!
tudor65
Reg: 03-07-14
06-03-19 10:36 AM - Post#2767609
Sir, I had the same problem with my 65 327. The problem was the mechanical advance in my Hei. distributor was rusty and stuck in the full advance position.I had to remove the distributor and take it apart to get it freed up. I put in new set of springs while it was apart. After that it always cranked up no matter how hot.Good luck.
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
06-10-19 01:29 PM - Post#2768147
    In response to tudor65
The the replacement of the module in the distributor seems to have worked! But thank you for your input!!
Execution time: 0.201 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:24 PM
