Chevs of the 40s
Username Post: Where to get brass block and bolt for rear brake cylinder        (Topic#356486)
05-19-19 07:06 PM - Post#2766751
Does anyone know where I can get this brass block and hollow bolt That is used on 51-54 cars for the REAR WHEEL brake cylinder?
Mine leaks and is damaged beyond use.
Attachment: DSCN2131.JPG (4.31 MB) 0 View(s)
Chevs of the 40s
Kyle G.
Loc: Delanco, New Jersey
Reg: 11-29-15
05-19-19 08:04 PM - Post#2766756
It's called a banjo bolt. They should be pretty universal. If you do some shopping around and measure your bolt thread size you should be able to find them pretty cheap. I'm sorry I can't give you an easy link to a set.
1950 Chevy Styleline Deluxe w/ '60 235 engine and '58 torque tube 3-speed overdrive with 3:55 gears in the back
1946 Willys CJ-2A
Edited by Kyle G. on 05-19-19 08:11 PM. Reason for edit: No reason given.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
05-19-19 10:31 PM - Post#2766760
LINK:
https://www.chevsofthe40s.com/detail/15695/Chevrol...
1951 Fleetline
05-20-19 06:45 AM - Post#2766772
    In response to RAM_51
That block is for the master cylinder, which is different from the block used on 51-54 rear wheel cylinders.
RAM_51
RAM_51
Reg: 12-28-02
05-20-19 06:54 AM - Post#2766775
My mistake....the only other one that chev's shows is for up to 1950 with a 1/4" brake line...is the 1951 different?
LINK:
https://www.chevsofthe40s.com/detail/15694/Chevrol...
1951 Fleetline
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
05-20-19 07:34 AM - Post#2766779
May be urban legend, but I've been told the 51 thru 58 brakes are the same, may give you options on block and bolt. Just a thought.
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
05-20-19 07:38 AM - Post#2766782
Yes, it's different. The 51-54 cars used 3/16 brake line.
BUUUUUUUUUUUUUUUT, I do have an option--------------which I do not want to go with, unless I cannot locate a block and bolt.
I can switch the rear wheel cylinders to 55-57 style.
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
05-20-19 07:39 AM - Post#2766783
    In response to one4dad
So sad, but true. I also have a '58 and the massive 2" wide brake shoes (including Corvettes) and related hardware are the same since '51.
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
RAM_51
RAM_51
Reg: 12-28-02
05-20-19 08:05 AM - Post#2766785
This does not give dimensions...you may have to contact the firm to find out for sure...but I know that many of the car and light truck brake components are interchangeable and this does list as 1951-1955.
LINK:
http://www.classictruck.com/product/1951_1955_Bra k...
UPDATE:
Here's what the Master Parts Catalog says:
Group 4.686 NUT, Inverted Flared Tube
1951 PASS. 1/2 TON....CONNECTOR, rear wheel cyl. inlet (3/8-24) 3696553
1951 Fleetline
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-20-19 08:57 AM - Post#2766791
There are two of them on this 52 rear-end leaning against my front porch, if you need them, you can have them.
19chevy48
Reg: 04-08-19
05-20-19 09:23 AM - Post#2766796
    In response to gcrkfrd
Try the filling station.
05-20-19 09:29 AM - Post#2766797
YES! Let me know.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-21-19 07:43 AM - Post#2766843
Attachment: 5_21_19_001.jpg (806.16 KB) 1 View(s)
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-22-19 09:24 AM - Post#2766933
Do not forget to Anneal Copper Washers before install.......
Attachment: 5_22_19_001.jpg (862.12 KB) 1 View(s)
Edited by gcrkfrd on 05-22-19 09:26 AM. Reason for edit: No reason given.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-22-19 09:44 AM - Post#2766935
Did not mean for this to be here, was sending Tracking Number, and estimated delivery date.
Chevs of the 40s
Execution time: 0.176 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:35 AM
