Username Post: Temperature sending unit for 55        (Topic#356478)
55nomad
Member #742 "17th Year" Gold Supporting Member
55nomad
Loc: Spring, Tx
Reg: 12-27-02
05-19-19 07:43 AM - Post#2766708
Greetings,
Where can I buy a replacement temperature sending unit for a 55. I'm considering upgrading to the electronic type for 56 but would like to know where I can get a stock replacement as well.
Tom
05-19-19 08:27 AM - Post#2766710
    In response to 55nomad
55 has a mechanical temp gauge and the sender is part of the gauge with a sealed capillary tube connecting them. Can't replace just the sender. The vendors have reproductions.
The electric 56 gauge fits the cluster and you need a 56 sender that is a one year only sender. No other sender will work right.
55nomad
55nomad
Loc: Spring, Tx
Reg: 12-27-02
05-27-19 08:19 AM - Post#2767172
    In response to acardon
Thank you.
Tom
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
09-12-19 11:04 PM - Post#2775437
If you have a stock 55 intake manifold there is no provision for the 56 temp sending unit. The 55 sender is a smaller thread at the back of the intake manifold whereas the 56 and later sending unit is a larger pipe thread hole up front on the water cross over.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
Execution time: 0.198 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:33 PM
