Username Post: Remote charging port        (Topic#356467)
baehrelw
Loc: west michigan
Reg: 12-16-15
05-18-19 04:40 AM - Post#2766651
My 1950 3100 is a restored stock truck (except for a dual master cylinder). I would like to add a port for charging the stock under the floor battery. Anyone have a solution that they can share that still will appear to be original? Thank You
Nailheadv8
Nailheadv8
Loc: Gardena, CA
Reg: 09-05-07
05-22-19 08:22 PM - Post#2766967
    In response to baehrelw
Get a forklift electrical plug.
Hook the cables to the battery,
hide the connector under the vehicle.
I hope this helps.
A PROUD MEMBER OF THE BABY BLUE T-SHIRT BROTHERHOOD
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-23-19 08:41 AM - Post#2766980
    In response to Nailheadv8
Looked at a Truck, the other day, that had one of those cigar lighter plug in jump starters rigged to a trickle charger. Guy said it worked fine.
52 Styleline Fourdoor 62 235 PG
BAM55
BAM55
Loc: Inglewood, CA
Reg: 02-22-11
05-29-19 09:24 AM - Post#2767284
I also have my battery under the cab floor so I added remote battery terminals to my inner fenders. I purchased them from speedway motors. You can see them in the lower left corner of my inner fenders.You can hide them any where you like.
My Chevy Truck Project
Edited by BAM55 on 05-29-19 09:26 AM. Reason for edit: No reason given.
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
05-29-19 08:28 PM - Post#2767302
Check out the products at this site.
https://www.alliedelec.com/industrial-rectangula r-...
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
Execution time: 0.177 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:31 AM
