Username Post: Dual Batteries        (Topic#356443)
albyneau
Reg: 08-28-04
05-16-19 10:47 AM - Post#2766548
Anyone know if GM produced a dual battery setup for these trucks? If so, might you have PN#'s?
TIA,
Scott
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-16-19 04:03 PM - Post#2766567
    In response to albyneau
They did but I don't know any part numbers. The 6.2 and 6.5 diesel trucks had dual batteries. All you would need would be the battery tray. You can make good top post cables cheaper than you can buy the factory ones. I really don't like side posts.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-16-19 06:03 PM - Post#2766577
    In response to bowtie44s
Other battery goes on the other side.
Same position, just different side of the truck.
You may have something in the way of installing the other tray but IIRC it is minor
Old School GM fan FOREVER
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
05-20-19 03:18 AM - Post#2766763
    In response to rockfangd
^^^ on my 94 I think the only thing that gets relocated slightly would be the fuel vapor canister (charcoal can). Otherwise yes, a new tray (side specific) and cables.
http://www.lmctruck.com/icatalog/cd/full.aspx?Page...
I think I would wire in some kind of dual battery management system though to give more flexibility.
Edited by scrambldcj8 on 05-20-19 03:22 AM. Reason for edit: No reason given.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
05-21-19 07:49 AM - Post#2766844
Both of my 99 Tahoes and my brothers 99 Suburban all had dual battery trays from the factory. They usually have an underhood storage box clipped into the driverside tray.
Edited by 1983G20Van on 05-21-19 07:50 AM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-21-19 07:21 PM - Post#2766897
    In response to 1983G20Van
It varies.
I had a 97 that the storage box was bolted in the place of a battery tray.
I wanted to install it in my 90 but I had issues. I cannot remember what it was, but I believe the canister was one of the issues, and possibly my washer jug
Execution time: 0.099 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:12 PM
