Username Post: 1405 Edelbrock fuel smell Secondaries?        (Topic#356430)
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
05-15-19 02:05 PM - Post#2766479
Hello All,
I have an Edelbrock 1405 that at passing or wide open throttle I get a strong fuel smell that disappears after a few minutes. Around town or cruising on freeway no issues just at wide open throttle. Could the jets in the secondaries be to big? I never changed the needles or jets I've adjusted the floats correctly car runs great but only fuel smell at wide open .Any help appreciated!
1967
307
400 Turbo
05-16-19 09:08 AM - Post#2766542
    In response to Mja1975
Get that in my car also. Open air cleaner and poorly sealed firewall are the reason.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-16-19 11:09 AM - Post#2766550
youve more than likely have a float level needing adjustment, or a defective fuel pressure regulator
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
05-16-19 11:54 AM - Post#2766551
    In response to grumpyvette
Thank you both for your replies! I have adjusted the float levels . I was able to adjust the floats to 7/8th with the air horn upside down but did struggle with the float level right side up. I will attempt again. I also have a few unsecured fire wall holes.
Thanks again.
1967
307
400 Turbo
Execution time: 0.101 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:51 AM
