Username Post: Cant adjust lash        (Topic#356420)
Tstopher
Loc: Beaumont, TX
Reg: 05-14-19
05-14-19 08:54 PM - Post#2766420
Probably something simple but here is what I have.
496, mutha thumpr hydraulic flat tappet cam, flat tappet pro magnum lifters, both brand new.
Using studs in heads for rockers, poly lock and roller.
Going through the assembly valve lash for zero I have a rocker that the nut is all the way down and cant tighten enough down to set the lash.
Is this a stud issue? Could the pushrod be bent so slightly I cant tell? Maybe a rocker problem?
Never experienced this. This engine has not been run.
70 Nova Pro Street
496 TCI TH350 Ford Big 9"
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-15-19 07:47 AM - Post#2766448
    In response to Tstopher
step one
verify your valve train geometry and push rod length
you'll want a adjustable push rod and rocker geometry check tool
https://www.youtube.com/watch?v=dbw8W8Oa6BQ
once youve got the correct geometry checker clearances,
and verified push rod length chances are excellent your issues resolved,
if not, check for cam lobe and lifter wear or clearances issues in the valve train
Proform Pushrod Length Checkers 66806 BBC 7/16" rocker studs
https://www.summitracing.com/parts/pro-66806
http://www.summitracing.com/parts/tfs-9001 (7.5-to-8.7")
http://www.summitracing.com/parts/tfs-9000 (6.125-to-07.5")
Edited by grumpyvette on 05-16-19 06:56 AM. Reason for edit: No reason given.
Execution time: 0.096 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:40 PM
